Dpf/new exhaust questions
So I'm going to be purchasing new headers and exhaust here soon (leaning towards banks, up to other suggestions by the way) but my main concern is deleting the dpf. In deleting this will this screw up my emissions, will I be throwing any codes, and is there anything else I should keep in mind or know before taking on this weekend warriors challenge?
2010 daily driver 250 no other mods as of yet. Starting with the exhaust because its just a little to quiet for my as@hole neighbors
You will need a tuner before removing the exhaust.
Yea, I actually put up a post earlier and just got a reply, for some odd reason I wasn't showing that it posted. Ah we'll. I was told in doing so I won't pass emissions so apparently the dpf is staying. I'm assuming others have found set ups keeping this. Anyone have any suggestions on what they liked/didn't like so I don't fall into a crappy set up I absolutely hate?
If you plan on keeping the dpf then I would look into the banks unit. Not sure what the model number it is but it seems to be pretty common with the guys who keep the dpf on.
The only reason I have to keep it is to pass emissions. I'm not so lucky to live in a place with no emissions. Are there anyways of deleting it and still pass emissions?
I think I've seen posts of guys who said they were deleted and still passed an emissions test.
Any decent emissions test is going to catch you so I wouldn't depend on passing them even with what some people suggest. The Banks tuner or even the Mini Max with DPF on settings may get you through a test, but that means keeping the DPF on.
You won't see the kind of gains people are seeing with the deletes. I'm speaking of power and MPG. The DPF is a pretty big road block on both of those fronts. Why did you purchase new headers (I'm guessing you mean exhaust manifolds)? The stockers are up to snuff unless you start pushing big power. |
I haven't purchased anything as of yet. I'm doing my homework before I do. A buddy of mine did mini max and swears by it. He deleted the dpf and stated it was a night and day difference. Was a dodge but I'd assume the "power" feeling would be similar. He also told me you can pass emissions without it, but is more of an athetics thing which they just look at it and if its not there you will fail. Another guy told me there are places which you can go to which will pass you without a dpf but its an underground thing, prob going to do it and deal with that headache when it comes. And as far as headers ( I've always called them that anyways) but exhaust manifolds will stay. I'm still under warranty and going back to reinstall the original ones would just be to much of a pain. And seeing how I blew the motor at 35k and received a new one with an unlimited mileage warranty for 3 years i have to be careful of what I do just in case something does happen.
You can always delete it, then when it's time to do your emmissions put your stock exhaust back on. That's what I will end up doing when that time comes, but I will probably try and have it done as is and see if I can get away with it.
