Bypassing egr cooler coolant flow... - Ford Powerstroke Diesel Forum
Old 01-30-2013, 11:28 AM
What is the best way to do this? The kit from dfuser makes it look really easy with only 1 long peice of hose? How can I just bypass both egr coolers?? Do I just hook a hose up to where the coolant exits the motor and starts into the cooler and then connect it to where the coolant re-enters?? This would be the 3/4 inch line....what do I do with the 3/8th line that goes to the Venturi tee on top of the vertical cooler? Delete the tee and just make that a splice? Any help is greatly appreciated! I have the right dfuser plates coming but also want to bypass the coolant flow....the more specific you are the better! Thanks in advance!!
Old 01-30-2013, 12:35 PM
Feedback Score: 7 reviews
Pics would even be MORE better hahaha
Old 01-30-2013, 01:29 PM
You can never not have "morer" than enough pics! lol...
Old 01-30-2013, 02:06 PM
Why would you bypass the egr coolant? Just do an EGR delete and remove the EGR and coolers altogether!
Old 01-30-2013, 03:08 PM
Do this to pass a visual inspection, but have every benefit of egr delete.. it can be done in such a way returning to stock woild take less than half an hour...
Old 01-30-2013, 03:11 PM
You still need to block off the EGR exhaust or else you will have high temps in the which in thurn may cause the coolers to fail anyway so I would say put plate on and put the coolers back on so it looks factory
Old 01-30-2013, 03:15 PM
Reroute AND plates...
Removing and reinstalling coolers every year? Helz no..
This is a much better and quicker option that that..
Old 01-30-2013, 03:18 PM
So buy the bullet proof coolers from a vendor. It seems that you want to eliminate cooler failure but you don't want trouble during an inspection so you have to do a risk versus gain assessment!
Old 01-30-2013, 03:41 PM
Yeah, if you can't do the delete I'd say the best bet is Bulletproof upgraded coolers. I probably wouldn't do that though unless my stock coolers were failing.
Old 01-30-2013, 03:42 PM
Amen
