Vacuum line on bottom of degas bottle - Ford Powerstroke Diesel Forum
Old 01-29-2013, 02:18 PM
Can someone tell me what this is for and how necessary it is?
Old 01-29-2013, 02:57 PM
4x4 auto system. I broke that line somewhere down there when I did my egr delete and I have to put hubs in manual now til I fix it.
Old 01-29-2013, 03:18 PM
Why does there need to be a vacuum line to the bottom of the degas bottle that is my question. I ask that because there is nothing at the bottom so why make a vacuum line go there? Just seems weird but there has to be a good reason.
Old 01-29-2013, 03:30 PM
Yeah I dunno, only thing Im aware of that is vacuum operated is the auto hubs..and those stupid little, brittle lines are everywhere!!
Old 01-29-2013, 03:48 PM
I bought some fancy LED lights for my truck and they need Load resistors so I don't get hyper flashing and they needed to be mounted close to the bulb because the wires are super short. So I drilled a hole that I thought I had plenty of space for and put a hole in my battery and I thought the acid went to the bottom so i drilled a hole to let the liquid drain and nothing came out and then I drilled another hole in the middle to mount the resistor and right around that time the pump started running non-stop and I had no idea why. Today I put 2 and 2 together after wondering why my 4WD wasn't working and realizing the vacuum line went into the bottom. So I plugged up the holes and sure enough everything works again. So luckily my lines are in tact.
Old 01-29-2013, 03:57 PM
Dang man!! Ive just been to lazy to try and find where my line is cracked/broke and so I just unplugged that annoying vacuum pump, been well over a year now.
Old 01-29-2013, 04:04 PM
Yeah... I'm retarded.
Old 01-30-2013, 05:08 AM
I don't have the vacuum lines, my transfer case shifter is on the floor
Old 01-30-2013, 05:18 AM
Floor board shifters for the win!
My vacuum line came out during the EGR delete. I don't have a button in the dash, so I don't need no stinking vacuum lines
Sent from AutoGuide.com App
Old 01-30-2013, 01:08 PM
You guys with the floor shift can still shift on the fly right? I don't see why it would be any different having to do it manually instead. Just curious.
