Regen message? - Ford Powerstroke Diesel Forum
Old 11-27-2007, 09:52 AM
Regen message?
I have an 08-F250 6.4. I have 2 friends, both also have 08's, 1 is an F-250, the other is an F-350, both have the 6.4 diesel.
They are given a message on their message center that the truck has entered regeneration.. I do not. I've never seen any message about regeneration.
Mine is definitely going into regen, I can see the rpm at 1200 in park and definitely feel the power difference, and smell while driving.
I called 2 dealerships here locally. 1 says it should say it is in regen, the other said it should not. My owners manual clearly states that I should see one or several messages while in regen.
Any thoughts?
Old 11-27-2007, 01:49 PM
i would beleive the owners manual. have the dealer check it out next time your in there.
Old 11-27-2007, 02:33 PM
Ya I've called a half dozen dealers today, spoke with 6 service managers and I'm finding that most are clueless about anything to do with this 08 6.4. Scary thoughts if/when service is needed. 1/2 of them say it should say something, 1/2 say it wont, literally.. 3 votes each! I asked about any TSB's for it, they all say nothing shows for it. Go figure.
Old 11-29-2007, 08:11 AM
Let's Run'em
I have never seen the message when I saw regen was still active on my truck....it maybe a new feature for the newer 08's but I know mine doesn't have it
Old 11-29-2007, 03:13 PM
same here as Julian, 80,000 miles several hundred regen cycles and never once any type of message
Old 11-29-2007, 03:53 PM
I have never seen a regen message either on my 6.4.
Old 11-30-2007, 03:41 PM
Mine did it yesterday and today...
Old 11-30-2007, 04:08 PM
I found out that there was a Message center TSB, update released in July. Take it in if you want those messages.. but the same update also warns/prevents you from driving right away if the turbo is cold, or warns you of impending shutdown if too hot.
Old 12-02-2007, 07:09 AM
How did you find out about this "update" and why aren't all 08 owners notified of these updates when they are released.
Old 12-02-2007, 07:30 AM
Someone (perhaps in another forum?) linked me to this TSB. So I called around and found a Service Manager who wasn't completely clueless and confirmed that it indeed does, though not mentioned, inform you when the truck is in Regen.
I have uploaded the TSB here: TSB-07173
