EGR tuned off / wastegate question - Ford Powerstroke Diesel Forum
Old 01-25-2013, 09:17 PM
Sic2Fiddy
I am running the Spartan 250 tune which turns off the EGR, does this also tune out the turbo using the EGR as a wastegate?
I want to do an EGR delete but I am considering the delete with wastegate.. what are your guys thoughts? is it necessary? Anyone have any problems with an EGR delete running a 250 tune?? Thanks
Old 01-26-2013, 11:37 PM
Sic2Fiddy
bump.. anyone??
Old 01-27-2013, 09:24 AM
I don't run spartan but as long as you have a egr delete tune go for it. Otherwise call the guys at spartan and I'm sure they fix up your tuning for whatever you want to do....
Old 01-27-2013, 09:28 AM
Wastegate is not needed unless you throwing big sticks in your truck and a bigger turbo btw...with a stock pump and injectors you won't need a wastegate, just a delete would be fine...
Old 01-27-2013, 10:07 AM
You don't need a wastegate unless you swap turbos or start throwing big boost/volume at this engine. You're not going to do that with factory turbos and a tuner as far as I know.
So, in other words, just get an EGR delete and don't worry about the wastegate.
Old 01-27-2013, 01:06 PM
As well spartan has all the egr delete tunes available on their website for download.
Old 01-28-2013, 12:44 AM
Sic2Fiddy
ok.. General thoughts are no need for wastegate. thanks guys.
Old 01-28-2013, 05:15 AM
what's with the stock exhaust or at least stock exhaust tip bro????
Old 01-28-2013, 08:20 AM
I have stock exhaust tip on mine. I don't like the look of a single pipe coming out one side and I also don't want to spend money on going duals.
Makes it more of a sleeper. Ha!
Old 01-28-2013, 08:23 AM
re: exhaust tips..
mine is vanilla as can be.. I've been searching for a tip that looks like stock but will fit a 4", but can't seem to locate one.. I don't want to cut the one off the stock exhaust I've kept in the garage..
there is going to come a day, I fear, that your local HP will be briefed on what to look for, and all of us with aftermarket tips will be nailed..
