2009 f350 6.4l white smoke no codes - Ford Powerstroke Diesel Forum
Old 01-18-2013, 01:51 PM
Ok guys i need some help and some light on this problem. a 09 f350 had a code for misfire on cyl #2 was smoking really bad and had a knock. we replace the injector no more codes. but still misses a little and I am getting this values for the fuel trim
cylinders
1= 3
2=16
3=1
4=0
5=8
6=4
7= -20
8 =-5
what do you guys think is going on i have no codes.
Old 01-18-2013, 07:21 PM
Powerstroke Techie
I'd check the compression... 6.4's are pretty unforgiving when it comes to burning down cylinders when an injector leaks.
Old 01-18-2013, 08:58 PM
I had it running for a good 5 minutes and fuel started leaking out of the muffler and clouds of white smoke. It idles fine and i have no missfires. What about cylinder 7 at -20%?
Old 01-20-2013, 06:06 PM
Anybody have any ideas?
Old 01-21-2013, 05:47 AM
Powerstroke Techie
It's cutting fuel ... Suspect that injector is leaking also.
It's pouring fuel out the tailpipe now, after the #2 injector replacement?
Old 01-21-2013, 04:05 PM
no at fisrt it wouldn't turn on, we replaced the injector and now it runs but it blows tons of white smoke and there is diesel coming out of the exhaust pipes.
that makes sense on 7 and 2 I think I am going to try another injector.
Old 01-22-2013, 11:23 AM
Problem Fix, Replaced Injectors on Cylinder 5,6,7,8 they where leaking.
