the NC part was painted PVC and looked kinda cheap
I would do my own also but keep in mind done wrong can cause issues |
I kinda want something in the way of a metal can, especially being under the truck exposed even if it is tucked up to the frame. A pic of someone's would be helpful since I'm more of a visual type person. Especially for the filter media inside, don't know what to use?
I would run everything myself but wouldn't mind just getting a pre made metal can. I think a PVC can is kinda chinsy and don't want one only truck. Plus with being kinda a perfectionist who knows how long it would take me to fab something up :/
Filter media could be aluminum drill press/ lathe shavings
Sweet my dad works at a machine shop! How do you keep the shavings in the housing without blowing out of the can and back into the intake?
I would sure as hell not put metal shaving in it. Plastic brillow pad material.
Closed system ccv question
Ofcourse it needs to have correct screening installed. That's how some of the best catch cabs are built. Let me find done links n pics
I used 2 1/2 inch exhaust tubing, stainles steel pot scrubber pads, some stainless steel fine metal mess screen and a mig welder to make mine. Although it did take me several hours to get it the way I wnated.
I wondered bout that after I read it..
You happen to have any pics of your setup?
