Baro sensor location? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 01-11-2013, 09:47 AM Thread Starter
srjd's Avatar
Quoted: 2 Post(s)
Could somone tell me where the baro sensor is on the 6.4. It's not the same as map senso right?
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #2 of 10 Old 01-11-2013, 10:01 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
This is what i found
Baro Sensor (Barometric Pressure)
A 5-volt reference signal is is supplied to the baro sensor and it produces an analog output signal. In the 6.4L, the sensor is located in the ECM, while the earlier engines use a remote sensor. The primary function of the baro sensor is to provide altitude information so the timing, fuel quantity, glow plug on time, and turbocharger boost can be altered.
Read more: Ford Power Stroke Engine Controls - Diesel Power Magazine
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 10 Old 01-11-2013, 10:08 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Here is another good description.
http://www.hsperformance.com/1/image...Components.pdf
08 F350 cc/sb 4X4
post #4 of 10 Old 01-11-2013, 10:11 AM Thread Starter
srjd's Avatar
Quoted: 2 Post(s)
Mine is a 01/07 build so I will have to find where the remote location is. Thanks for the help
srjd is offline
post #5 of 10 Old 01-11-2013, 10:18 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
According to what i read if the baro sensor is bad the ECM needs to be replaced because the sensor is inside the ECM.
Baro (Barometric Pressure)
• The ECM supplies a 5 volt reference signal which
the Baro sensor uses to produce a linear analog
voltage signal that indicates pressure.
• The primary function of the Baro sensor is to provide
altitude information so that the ECM can adjust timing, fuel
quantity, glow plug on time, and turbocharger control.
• The Baro sensor is located inside the ECM. If the
sensor fails, the ECM must be replaced.
08 F350 cc/sb 4X4
post #6 of 10 Old 01-11-2013, 05:30 PM Thread Starter
srjd's Avatar
Quoted: 2 Post(s)
That's not good i wonder how much one of those are and can I do it myself?
srjd is offline
post #7 of 10 Old 01-12-2013, 06:54 AM Thread Starter
srjd's Avatar
Quoted: 2 Post(s)
What about the map sensor I know it's on passenger side manifold but there are two sensors there which one is it and what is the other sensor? Thanks again for the help still trying to fix my turbo problem
srjd is offline
post #8 of 10 Old 01-14-2013, 09:19 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
The sensor closer to the front of the truck is the MAP sensor. The one behind it is the IAT2 sensor. You might as well clean both while your at it.
08 F350 cc/sb 4X4
post #9 of 10 Old 01-14-2013, 09:21 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I just ordered new sensors and replaced them. They are not that expensive. Here is a picture of all three sensors.
08 F350 cc/sb 4X4
post #10 of 10 Old 01-14-2013, 02:58 PM Thread Starter
srjd's Avatar
Quoted: 2 Post(s)
I just changed the map sensor and ebp tube yesterday. The ebp sensor I replaced 3 weeks ago. Anyways the map sensor was almost completely clogged. My fuel milage has since improved and my turbo issue of hitting 40 psi randomly has been resolved. I still get a 0kpa on the baro but like you said its in the pcm I'm just going to leave it alone. I can't believe how much of a difference those sensors make.
srjd is offline
