6.4 idling rough cold... - Ford Powerstroke Diesel Forum
Old 01-10-2013, 06:16 PM
I am running the h&s hd 300 tunes on wild for DD. Twice I have started my truck (last 2 nights) and found it idling quite rough. I recently re-loaded my tune to adjust transmission settings...it has never done this before...if I shut it off and re start it runs perfectly...anyone else deal with this?
Thanks guys...
Sean
Old 01-10-2013, 06:33 PM
Ooo no i havent how cold is it?
Old 01-10-2013, 07:28 PM
It's warming up around me, around 30-40, but very humid and raining....going to reflash and see what happens....
Old 01-10-2013, 07:35 PM
Alright sounds weird. Um email H&S and ask tell them and they sould really help you!!
Old 01-10-2013, 08:51 PM
Are you letting the glow plugs get ready?
Old 01-10-2013, 09:42 PM
Even at 30-40 without letting the glow plugs warm up it won't idle rough. I can start mine below 0f and it will only be rough for 1 sec tops then its fine. That's weird that you restart it and its fine tho. Sorry I couldn't be more help
Old 01-11-2013, 04:25 AM
Yup, Im letting the glowplugs warm up of corse. I don't know if I have a bad sensor?? I cleaned my maf but it really was not dirty...I emailed h&s and I loaded the latest tune version to my xrt pro so I'll see what happens when I re-load my tunes...maybe h&s will have more insight?
Old 01-11-2013, 05:25 AM
I forgot to mention, both times I've started my truck with my remote start and when I get in it and put my key in then press the brake when the high idle goes down that's when I really notice how badly the truck is running. Of corse I have these horrible ideas of Injectors sticking or egr's leaking and melted motors and bent parts...
Old 01-11-2013, 05:32 AM
Just checks codes...p0263, cylinder one....grrr....truck had the 3 bad injectors replaced 20k ago by ford...
Old 01-11-2013, 05:48 AM
Do you still have dpf or egr?! Um is your truck still under warenty
