Turbo psi vs Exhaust Back Pressure (EBP) psi - Ford Powerstroke Diesel Forum
Old 01-10-2013, 07:23 AM
I was wondering how far apart these numbers should be under different conditions and loads and if it means anything? I'm assuming turbo pressure and EBP are chain linked so they should have some sort of healthy relationship when your truck is running how she should. I've only compared at cruising speeds (70-80mph) so I don't have a great base to judge from but those numbers were consistently 3-5 psi apart with the EBP bein the higher number I thing (could be wrong).
Any ideas, thoughts, personal experiences, or comments? I'm no mechanic or mechanical engineer...I'm just a lowly civil engineer who tries to be one!
All y'all who are smarter than me feel free to drop some knowledge. Thanks in advance!
Sent from my iPhone using AutoGuide.com App
Old 01-10-2013, 09:26 AM
They should be as close to 1:1 as possible.
Old 01-10-2013, 11:08 AM
What does it mean if they are not? Clogged EBP sensor?
Old 01-10-2013, 09:56 PM
Not sure but if your ebp is completely clogged you will know. Hardly any power and turbo 40 psi when barely on the throttle
Old 01-10-2013, 10:01 PM
I think mine are different I can't tell the sct I messed up everything is measured in different ways with kpa or psi. At idle it says desired ebp 28 and the actual is 112. Not sure i may have a problem too
Old 01-10-2013, 10:21 PM
Just found this on a different site. (My ebp is 15kpa higher then map at idle hope that's ok).
You'll need an accurate pressure gauge for boost and exhaust back pressure. The dash daq provides these readings as such; manifold gauge pressure is the same as actual boost pressure. EBP (exhaust back pressure) is atmospheric pressure + exhaust back pressure. MAP (manifold absolute pressure) is boost pressure + atmospheric pressure. It is easiest to use MAP and EBP as readings, but if you like math, you can use MGP and EBP - atmospheric pressure. The ideal street ratio is approximately 10 psi actual peak exhaust pressure higher than actual boost pressure. For example, If your EBP reads 75 and your MAP reads 65, you're perfect. Assuming an atmospheric pressure of 13 psi, you'd also be perfect having EBP of 75, and MGP of 52. To know your actual atmospheric pressure, look at EBP or MAP with key on, engine off.
Old 01-11-2013, 11:04 AM
That's exactly what I was looking for.
SRJD--you are the man. Thanks bud!
Old 01-11-2013, 03:31 PM
Mine run around 15 to 17 kpa difference between ebp and intake pressure.
Old 02-21-2013, 08:22 AM
What should the ebp show when the key is on but the engine isn't running? Mine shows 4psi on my mini max. Does anyone know how to see the map pressure on the mini max?
