Injector rattle?
Anyone else notice as your 6.4 gets more miles its starting to sound louder? In colder weather my injectors makes lots of noise between 1700-2100ish rpm until it shifts into overdrive then you can't hear a think. Is this normal?
What tune do you run? I've ran some tunes that have injector rattler bad then others(h&s) that have zero. So I would say its probably not posing a problem.
Some of the older tunes have that issue.
Fuel quality could also change the sound as well, I would check your filters. Run a good quality fuel additive. I've also found that mine idles a lot quieter with synthetic oil and the Archoil 2300 (cleaner). |
I'm just running kem 175 tune. I've heard some do it more then others I guess the spartan 310 is bad and even some stock trucks. I just read that since I posted it. My truck has always done it but it just sounds terrible like the valves are going to explode then after 2k rpm and boost builds it sounds perfect.
I run synthetic it gets changed every 3k miles. Fuel filters every 7-10k miles and fuel additive every time I put fuel in so who knows
I have 111,xxx miles on it. It's done it for a long time and I really hope it's not rockers. My truck was torn down twice in the past 6 months for HG issues and the second time they went over the engine and rockers looked fine. That was only 1000 miles ago
I also noticed my dads and brothers duramax a do it as well
i was going to suggest rockers too.. or, (sorry to suggest) valve springs or valve spring retainers.. if the spring is weak, the rockers are given room to chatter..
I have a high RPM chatter on the odd bank just before shifting 2-3, 3-4, and 4-5... it's not so bad 4-5, but it is there.. I'm all but certain it's valvetrain chatter of some sort.. likely weaker springs imHo.... I have 50k on my rig.. |
Who knows. I did lots of reading about it last night and seems to be very common. I remember last winter it did it too then real quiet or not at all in the summer. Now that winters back its doing it again. I really noticed it when I got the kem tune before that it was much quieter. I'm sure I'm just getting myself worried for no reason but I'm paranoid after all the trouble I had with it this summer and fall. I should just crank the radio up and drive the thing. I use to love driving my truck now every two min I go what's that noise???
