New to 6.4's, few questions - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-06-2013, 06:29 AM Thread Starter
Hello all, Just bought a 08 250. 6.4l
Truck has 116000 mi. seems like it runs good.
Anything i should be aware of with these motors? I pulled the vin and searched ford for recall info and it came up with no recalls.
other than that it runs very well, looks to be all stock, no mods yet.
thanks
jmiller79 is offline
post #2 of 7 Old 01-06-2013, 07:36 AM
superduty6.4's Avatar
The absolute most important thing is the maintenance schedule. Lack of maintenance can quickly become very expensive.
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #3 of 7 Old 01-06-2013, 11:02 AM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
Check out the 'General 6.4 Modifications' sticky.
Sent from my iPhone using AutoGuide.com App
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
post #4 of 7 Old 01-06-2013, 03:40 PM
Doss's Avatar
Quoted: 17 Post(s)
I'd get an OASIS report for it to see what fixes have been applied or done.
Then, I'd start saving up for deleting everything you can (EGR, DPF,Cat).
I'd also make sure it has fresh Motorcraft fuel filters and oil filters.
Change the coolant out (especially if it's never been done before). The rear end fluid needs to be changed. The transmission fluid needs to be changed and possibly a filter change too. Same goes for the transfer case fluid.
It's probably about time for the brake fluid to be changed too.
This will probably keep you busy for the better part of a weekend at least.
It may be your only purpose in life is to serve as a warning for others.
Doss is offline
post #5 of 7 Old 01-06-2013, 03:51 PM Thread Starter
Green trans fluid?????
ThaNKS FOR THE REPLY'S
jUST NOTICED A LEAK AT THE REAR TRANY PAN BOLTS. DRAINED ABOUT A CUP OF TRANSMISSION FLUID AND ITS DARK GREEN!!!! coolant leak????
post #6 of 7 Old 01-06-2013, 05:29 PM
Doss's Avatar
Quoted: 17 Post(s)
Uh... you drained transmission fluid and it was green?
I think you have a lot larger problems than a coolant leak (factory coolant is gold, factory transmission fluid is dark red).
Doss is offline
post #7 of 7 Old 01-06-2013, 07:50 PM
Did u say green?
Hogstroker72 is offline
