"check air filter" - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-05-2013, 07:07 AM Thread Starter
"check air filter"
this showed up on my dash display yesterday morning. i throttled the truck pretty hard from a green light and this "warning" immediately shows up. i opened up the air cleaner box and looked at the air cleaner. it looks fine so what it is i'm supposed to be "checking"? does it simply mean it's dirty and needs a new one or did i actually break something? i'm still running the factory air box if that makes any difference.
wide body is offline
post #2 of 8 Old 01-05-2013, 07:11 AM
Hunter of Trolls
drewactual's Avatar
Quoted: 66 Post(s)
Did you reset the little button on the housing? It's just before the maf/ait sensor..
drewactual is offline
post #3 of 8 Old 01-05-2013, 07:37 AM
Put in a new one and check. It may need changed, and u will then be able to tell if it the warning is bogus or not.
Sent from my iPhone using AutoGuide.com App
08 6.4
H&S Mini
PTP EGR Delete
4" Diamond Eye TB
Sinister Coolant Filter
S&B Intake
Recon Cab Lights
itn69 is offline
post #4 of 8 Old 01-05-2013, 08:07 AM Thread Starter
no i sure didn't. i didn't know there was one there. i'll see if i can track it down. thanx
post #5 of 8 Old 01-05-2013, 08:09 AM Thread Starter
when i took it out, it didn't LOOK dirty but that doesn't mean its not restricted enough to cause the sensor to not like how much air it's getting. i'm hoping to drag my feet a bit longer with the factory one because i want to upgrade it before too long.
post #6 of 8 Old 01-05-2013, 08:27 AM Thread Starter
sure enough, plain as day, there is a big blue button "press to reset"...
i heard a click when i pressed it so i'll see now if it comes back on. if it does, than i'll know my filter needs to be replaced.
thanks guys!
post #7 of 8 Old 01-05-2013, 10:55 AM
Doss's Avatar
Quoted: 18 Post(s)
That should be the issue. The filter minder (the gauge with the button you pushed) will max out if you run high boost (sucking in a lot air) with a dirty or even slightly dirty filter.
My filter didn't look too dirty, but I weighed it against a brand new Motorcraft filter and it was, if I remember correctly, about a pound heavier.
It may be your only purpose in life is to serve as a warning for others.
Doss is offline
post #8 of 8 Old 01-06-2013, 07:27 AM
raftdaddy's Avatar
mine used to do it everytime it rained hard and i was on the highway, s&b cai was the first mod. the stock filter is way to expensive to keep changing. when it gets wet its like a paper log.
2012 f350 lariat,35x12.50x20 on moto metal mo962 in 20x9 with o offset.bil 5100's,readylift 2.5 level
raftdaddy is offline
