Drain Water Seperator - Ford Powerstroke Diesel Forum
Old 01-04-2013, 09:51 PM
I have Ford F350 dulley the Drain Water Seperator light keep coming on my dash i tried everything i did read here and on other webs
1- I did Drain Water Seperator but the light came back on
2- Changed the Fuel filters but the light came back on
3- Dropped the tank and cleaned it frash fuel but the dam light came back on
each time after 10-15 miles light is back on
when i open the drain Fuel come out i think it has water and really sometimes i don't see anything
what else can be done
2008 Ford F350 with 71k miles
Old 01-04-2013, 10:11 PM
Take apart the housing on the frame mounted filter and clean it. It gets gunked up and will give false light. You will need a new gasket as well. Its easy to do.
Old 01-04-2013, 11:52 PM
Really easy to do I bet that's your problem. Sometimes the sensor itself just goes and it keeps saying that. At least now you have a clean tank. Out of curiosity how did your tank look
Old 01-05-2013, 06:46 AM
Common problem. If you keep your system maintained and it sounds like you do.....I'm betting the sensor is bad.
Old 01-05-2013, 10:57 AM
Yes, get the kit to replace the gasket and other parts on the side of the low pressure pump (under the truck). Remove the cover on the side (it contains the yellow drain lever) and clean it out. It's probably pretty gunked up. That will usually trip the sensor.
Worst case, you'll need a new sensor.
Old 01-05-2013, 06:57 PM
I will try that monday thanks for the advise everyone, but is it suppose to drain each time you open the drainer because everytime i open the lever
Old 01-05-2013, 08:58 PM
It did not really look bad i don't think there was water in the tank
my problem is each time the message come's on the dash i drain it and it does drain about a cup even some time more
Old 01-05-2013, 09:00 PM
but it does drain each time i open the lever
is that what should happen
Old 01-06-2013, 02:37 PM
Yes, every time you open that lever fuel or water or both should come out. And the flow should be enough to fill a 20 oz bottle in less than a minute... more like 30 seconds.
You should drain it into a clear container (like a plastic bottle) and check it for water. The water will separate from the diesel if you just let it sit for a little bit.
Old 01-06-2013, 03:18 PM
...the flow should be enough to fill a 20 oz bottle in less than a minute... more like 30 seconds.
Mine has NEVER flowed that much. Not even close.
Tags
6.4l problems, drain, fuel cleaner, fuel issue, sensors
