EGR block off is it really worth it?! - Ford Powerstroke Diesel Forum
Old 01-02-2013, 10:03 PM
Question EGR block off is it really worth it?!
Guys when finishing my truck i just looked at my egr
Honestly i run the h&s HD300 "wild" tune(225hp)
Is it really worth it to take the egr coolers off?!
I kept mine to the fact i herd that it acted like a wastegate and kept my back pressure down
Tell me if its really worth in to do the delete
Or keep the egrs as a wastegate
Old 01-03-2013, 04:42 AM
Delete it. It doesn't act as a wastegate. They don't cycle on the high tunes anyhow. Plus I wouldn't want the crap put back thru my engine. It cakes the inside of your intake manifold. Get rid of it and be happy you are making your motor more healthy.
Sent from my iPhone using AutoGuide.com App
Old 01-03-2013, 05:26 AM
Alright thanks!!!
Old 01-03-2013, 05:43 AM
I don't really see the need to take them off when the tuning turns them off
Old 01-03-2013, 05:59 AM
Coolant is still flowing thru them. And if you don't at least block off the inlet from your exhaust heat is still being introduced to them. Hence a fail point and it raises the temp of your coolant. Tuning them off is a weak bandaid. Block off plates are better and in my opinion are minimum because coolant still flows thru, but completely removing them removes the fail point entirely!
Old 01-03-2013, 06:10 AM
I've read/heard it all before. I just don't see the need.
Coolant is still flowing through them. Exhaust gas isn't. There's less heat going through them with the EGR turned off than there is with the EGR functioning.
Old 01-03-2013, 06:11 AM
agree, delete it
Old 01-03-2013, 06:20 AM
Alright im doing it today
Also for ya who have it deleted did ya take off the mounts that hold it?!
Old 01-03-2013, 08:49 AM
You do what you want. But without the inlet being blocked, hot exhaust is still entering even tho it isn't flowing thru.
Old 01-03-2013, 08:50 AM
I took off the horizontal bracket, the vertical is still there
