transmission question - Ford Powerstroke Diesel Forum
post #1 of 24 Old 12-30-2012, 01:50 PM Thread Starter
I just drained my fluid and pulled out my filter. The filter I got from Bumper to Bumper is not the same. I went to 3 parts store and they offer the same one. The filter that was in my truck is a little taller and has a paper filter. the number on my filter i took out was 7a098d the cross referance on atp is b360. I have a 2008 f450. Manufacture date 05\07. I need help figuring out why the differance? can I use the offered filter or do I need to go to ford and buy the one that was in the truck. Also whay the diffrence in filters. very confused.,
Zacfrd is offline
post #2 of 24 Old 12-30-2012, 01:52 PM
ZMANN's Avatar
Quoted: 1891 Post(s)
if u have a in pan paper filter u need to stick with it and it is the only type
the other is a screen and will fall out of the input hole without the proper pan
can u post a pic ? because your build date would suggest the screen type unless somone swapped pan and filter to a later build ?
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #3 of 24 Old 12-30-2012, 01:58 PM
ZMANN's Avatar
YourCovers.com Ford TorqShift Deep Transmission Pan
there is a third variation but the pan remained the same as the early model
and the filter was a canister at the bell housing
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #4 of 24 Old 12-30-2012, 02:01 PM
ZMANN's Avatar
PS Fram is the OEM if you can find one at a parts place
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #5 of 24 Old 12-30-2012, 02:40 PM Thread Starter
i dont have a pic but atp b360 part number is what it looks like. How do i tell which pan i have. I want to make sure and get this right. I have to tow 18,000 pounds long distance.
Zacfrd is offline
post #6 of 24 Old 12-30-2012, 02:41 PM
ZMANN's Avatar
the link i gave u has a demonstration
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #7 of 24 Old 12-30-2012, 02:44 PM
ZMANN's Avatar
the pic is a little hard to see but if u click them they enlarge
the in pan real filter has a deeper front drop in the 4x4 ish square area as the other is a recess
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #8 of 24 Old 12-30-2012, 02:49 PM Thread Starter
there is no ford logo on the pan??
Zacfrd is offline
post #9 of 24 Old 12-30-2012, 02:50 PM Thread Starter
i do not have a canister filter on truck
Zacfrd is offline
post #10 of 24 Old 12-30-2012, 02:50 PM Thread Starter
also how do i flush all fluid out of this truck
Zacfrd is offline
