Right coolant?
I'm pretty sure I got the right stuff here. Getting my coolant flushed next week by Strictly Diesel. I bought 5 gal of it and is the concentrate. Should this be enough?
Looks like it should work. I'm sure that will be enough. You'll also need about the same of distilled water unless they are looking after that part.
That is the exact same stuff I bought. Yes, it's "correct"... It has the CAT EC-1 rating.
You only needed 4 gallons, but the 5th won't hurt to have as a spare. You will end up having 1 gallon and a half left over. Provide them distilled water also to ensure they don't use tap. |
Thanks! I will get the distilled water then. Will I need about the same amount in distilled water?
Depending on how they flush it. Some guys do the initial flushes with tap water and the last flush with distilled before filling with coolant. When i did mine, I used all distilled water and went through 40-50 gallons
Dam cat elc last twice that
To answer your question about how many gallons of distilled to provide... the coolant system holds 27 quarts (almost 7 gallons) 3.5 gallons of concentrated coolant and 3.5 gallons of distilled water. But take in consideration what has been mentioned about the flush itself, and that part is up to you. If your paying someone to do it for you, then talk to them prior to droping it off and see how they are going to do it (or how you want them to do it) and then decide how much water to buy |
All good info. Thanks!
