power steering flush? - Ford Powerstroke Diesel Forum
Old 12-30-2012, 12:47 PM
I let my brother borrow my truck and he poured windshield washer fluid into the PS resivour.
What is the best place to flush open up the system to do a full flush?
Thanks for the help.
Old 12-31-2012, 06:50 AM
Here you go!
Ford Super Duty Power Steering Flush | Superdutypsd.com
Old 12-31-2012, 06:53 AM
7.3 4 Ever! Nothing else!
Feedback Score: 7 reviews
we have power steering flush/cleaner and fluid in stock!
The pump will need to be replaced, its JUNK!
Old 12-31-2012, 06:55 AM
Did you drive it after he put the washer fluid in it?
Sent from my iPhone using AutoGuide.com Free App
Old 12-31-2012, 06:56 AM
If that truck was started after the washer fluid was in it, Its junk
Old 01-01-2013, 02:54 PM
Thanks for the replies. He drove the truck to my house about 6 miles. He put about 4 ounces of fluid in before it filled up and he realized. Today I flushed it with about 10qts until the fluid was clear. Drove it afterwards and it worked fine. PS and brakes felt as good as they have for the last 4 yrs. Is it possible that there was no harm done or should I just suck it up and replace the pump to avoid a problem?
Old 01-01-2013, 03:02 PM
The pump should be good
Old 01-01-2013, 03:22 PM
If the pump is fine now, it should stay fine. If there was going to be a problem, I suspect it already would've shown itself.
Old 01-01-2013, 11:46 PM
So what would the differences be when performing this procedure on our 6.4l's? Which fluid? Looks fairly easy so this may be something I see myself doing in the near future.
Old 01-02-2013, 06:05 AM
The process is exactly the same. I did mine about 6 months ago. I used mobil 1 ATF.
