Throwing Turbo Codes- is this bad?? - Ford Powerstroke Diesel Forum
Old 12-28-2012, 09:00 PM
Yeah it's a Turbo Diesel
Feedback Score: 8 reviews
So my service engine light came on two days ago..I'm nervous as to what these codes actually mean. I cleared the codes with my edge cts insight tonight, I'll drive it some more tomorrow and see if the light or codes come back. But I wanted to check in with you guys and see what exactly these codes mean and how serious they are. No power loss issues, normal boost numbers- no loss in performance or over boosting..I researched the forum for these codes and it seems to be a coorelation with the cold weather. These codes popped up when we get the 20-40 degree weather the past few days. I cleared the codes so we'll see if they pop up again. I also saw in another thread that the ebp sensor could need cleaning. Now when I look at the ebp pipe and sensors, there appears to be two sensors, one on top and on on bottom. Which on is the problematic one that needs cleaned?
Codes are:
P2563- turbo charger boost control position sensor circuit range/ performance
P006B- MAP- exhaust pressure correlation
P2263- turbo/ supercharger boost system performance
P1000- ob2 system readiness test not complete
I hope this isn't anything serious and it's just a cold weather thing...but I figured with codes coming up about the turbo's I better run it by the org and make sure it's nothing to worry about!
Thanks for the help in advance, this forum has taught me so much and I try to give back anytime I can..
Old 12-29-2012, 06:12 AM
turbo probs
got me wondering if some of these snags aren't created by people who turn motor off early before turbo has had time to cool off....easy habit to get into
Old 12-29-2012, 06:25 AM
mts678 have you tried cleaning your ebp sensor & tube?
Old 12-29-2012, 08:46 AM
No not yet, I've been thinking about that though. I've driven about 50 miles today hard and easy and no codes. Is that a symptom of a dirty ebp sensor & tube?
Sent from my iPhone using AutoGuide.com App
Old 12-29-2012, 08:54 AM
I had same codes minus the MAP one. Take the sensor out up by valve cover and clean it out with brake kleen or similar. I havent had codes come back since I cleaned mine.
Old 12-29-2012, 09:15 AM
Ok thanks Clayton
I was reading back on a couple threads including Clayton's and like he just said they were getting some of the same codes. Seems to be coming up a little more often now that the weather is cool.
Old 12-29-2012, 09:23 AM
Ok thanks Clayton
Old 12-31-2012, 07:00 AM
Yup i had some of the same codes. I cleaned the EBP sensor and tube and the map sensor and so far so good. Clean the map sensor also while your at it.
Old 01-23-2013, 03:19 PM
Hey I have been having some of the same issues. I had the ebp tube replaced just before christmas after it broke and i have been getting these codes periodically since then. I also changed out the ebp sensor and cleaned the map sensor and these codes are still coming up. Getting kind of frustrated, just wondering if any other suggestions??
