Torque converter not locking.
Got a code of p0741 and p1744 torque converter won't lock in over drive anymore. Guessing I've gotta bad converter or solenoid. But which would it be? i passed someone this morning running about 60-70mph the tc unlocked and rpms raised a good bit. (it did not down shift). then i got a wrench light come up. checked the codes and got p0741 and p1744. trans temp never raised. now the next part i'm pretty much guessing at but someone correct me if i'm wrong. shouldn't the rpm and imput shaft rpm be the same? at least while the converter is locked?
anyone? really need some help to figure this one out
I would try the solenoid first and see if it fixes it. It sounds like maybe the solenoid is bad and therefore you couldn't hold drive line pressure to keep the converter locked.
Any one ever heard of checking the tc this way? its got some pics to just cant get them to load but heres the link to it http://www.atraonline.com/gears/2007...2007_03_08.pdf
Here’s a quick method for testing the pump and converter at the same time, using a tool you can build in 3 easy steps, from an old TCC solenoid: Step 1: Bend the 4 tabs back with a screwdriver (figure 4). Step 2: Remove the solenoid parts (figure 5). It isn’t Figure 4 necessary to remove the allen screw and spring from the tipof the solenoid. Step 3: Secure the solenoid plunger to the solenoid snout with a small hose clamp (figure 6). Be sure to align the hose clamp screw with the flat on the solenoid snout (figure 7). If it isn’t aligned properly, it won’t fit into the solenoid body.Now you’re ready to put your new tool to work on the transmission: • Drop the pan down and replace the TCC solenoid with the tool (figure 8). • Replace the pan and the fluid.…and you’re ready to go. I’ve done this procedure and it takes only 20 minutes, if that. CAUTION: This will engage the TCC all the time, and in all ranges. If the torque converter and pump are operating properly, the transmission will kill the engine as soon as you put it in gear. Engaging the transmission with the TCC applied will be very hard on the TCC lining, so keep your testing toa minimum. If the engine stalls with the test tool in place, the converter clutch and lockup valve are working properly. We already know the computer signals are correct. Last edited by JD_MILLS; 12-26-2012 at 09:47 PM. |
tranny codes!!!
Can anyone tell me what these two codes mean i've searched for two days now and still have yet to find an answer p1744 p0741
P0741: torque converter clutch performance/stuck on. Sent from my iPhone using AutoGuide.com App |
Ever get it figured out...mines doing the same thing. Has been for a few months actually. I feel your pain in trying to research this, I looked a while back and couldn't find anything conclusive. Ever get it fixed?
My torque converter started acting up just like this too. After a couple months of snowballing problems with my trans, I scrounged up some money for a custom trans to handle the higher horsepower tunes.
