Oasis Report?
Not sure if this is in the right section, but if some could run me an oasis report for my truck? VIN: 1FTWW31R38EC23901. Thank you.
-Aaron |
holy crap...
1FTWW31R38EC23901 Vehicle Line T/F7 Market Derived Code F Body Cab T/BC Ver. Series T/CD Drive Type T/E PLT CD A1 TRS CD T/BE ENG CD T/QL Production Date 23-AUG-07 Warranty Start Date 22-FEB-08 Selling Dealer 172407 Selling Country USA AWS Claim Key Trx Code Time In Service Labor Hours Dealership DIST (Miles) Repair Date Prefix Base Suffix Doc Details 999801 2 4 .5 CAL WORTHINGTON FORD LINCOLN 7828 13-JUN-08 * RECAL * 37833502 Customer Comments CHECK ENGINE LIGHT IS ON CAME ON ABOUT 200 MILES AGO Tech Comments VERIFIED CEL ON. SELF TEST EECV, FOUND CODE P0404. REFLASHED PCM PER TSB 081002A NOTE: CLIENT REQUESTED DOCUMENTATION OF DEFECT IN LEFT REAR DOOR SWITCH BEZEL, WILL SEE DEALER ON RETURN HOME. Details 1286229 2 6 .5 KENDALL FORD OF WASILLA 9804 01-AUG-08 * RECAL * 04487202 Customer Comments CUST CONCERN VEHICLE SEEMS TO REGENERATE TOO OFTEN. Tech Comments ENGINE HI IDLE INTERMIT SURGE INTERMIT PERFORM PRIMARY ENGINE PERFORMANCE DIAG STEPS 1 5 DTC P0404 P1335 EGR VALVE CIRCUIT REVIEW OASIS TSB 081303 PCM RECALIBRATION PERFORM PCM TCM I C REPROGRAM TO LATEST LEVEL 8U7A 12A650 MA CLEAR DTC STEP 7 KOER ON DEMAND PASS RESET KAM PERFORM EXTENDED ROAD TEST VARIFY ENGINE OPERATION PASS RETEST NO DTC RESET PASS Details 1531136 08B03 7 .9 CRATER LAKE FORD LLC 4532 03-SEP-08 * * * 42463706 Customer Comments PERFORM RECALL #08B03 Tech Comments 1 PERFORMED RECALL 08B03 INSTALLED FUEL TANK BRACKET Details 1531137 2 7 .2 CRATER LAKE FORD LLC 4532 03-SEP-08 7C3Z 14525 RA 42463701 Customer Comments CUSTOMER STATES THAT THE REAR LEFT WINDOW BEZEL IS FLAKING OFF. CHECK AND ADVISE. Tech Comments BEZEL,CODE D4 VERIFIED CONCERN WITH LR WINDOW SWITCH BEZEL,HAD SHOP MAN AGER LOOK AT ALSO,REPLACE SWITCH BEZEL OK NOW Details 1862130 08B06 9 .3 SHEEHY FORD LINCOLN OF GAITHERSBURG 19032 27-OCT-08 * * * 57355604 Customer Comments RECALL 08B06 VENTURI TEE INSTALLATION Tech Comments INSTALL VENTURI TEE KIT PER FSA 08B06 Details 2666804 E84 12 4.2 LILLISTON FORD OF KINGSLAND 24222 27-JAN-09 8C3Z 8009 B 00977202 Customer Comments C/S VEH DOES NOT DO FUEL BURN OFF ANYMORE SEN Tech Comments SE IN SHOP LAST TIME... PERFORMED INSPECTION FOUNDVEH LEAKING WATER ON THE SIDE AT JUG REPLACED RAD IATOR Details 2652079 08B07 12 .5 LILLISTON FORD OF KINGSLAND 24222 27-JAN-09 * * * 00977201 Customer Comments PERFORM RECALL 08B07 PCM / INST CLUSTER UPDAT Tech Comments E PERFOMRED RECALL Details 2840285 S07 13 9.9 JONES FORD 27456 16-FEB-09 8C3Z 9F464 D 01168901 Customer Comments CK ENG LT IS ON Tech Comments SCANNED. P0404,P042E,P2263,P1335. DOEO, KOER P042E,P0404.PERF PPT FOR EGR CODES. PIDS INDICATE NO EGR TRAVEL. REMOVE EGR VALVE FIND MOISTURE IN EGR SYSTEM AND COOLANT IN TAIL PIPE. REMOVE AND TEST EGR COOLER, BOTH FAIL LEAKING. REPLACE EGR COOLERS, EGR VALVE. RETEST AND OK. Details 3711575 S07 16 2 CRATER LAKE FORD LLC 35166 03-JUN-09 8C3Z 9F479 A 43547101 Customer Comments CUST STATES REGEN MODE EVERY 30 MINUTES DURING HWY SPEEDS,LOSS OF POWER DURING ACCELERATION FROM A STOP Tech Comments VERIFIED, PERFORM VISUAL INSP OK, OIL & FUEL QUALITY OK, DTC P0107,REVIEW DATALOGGER, CHECK MAP SENSOR FOR BIASED CONDITION, .73V,GOOD.CLEAR DTC.ROAD TEST,MONITOR PIDS, ENGINE RAN GOOD,DID NOT GO INTO REGEN MODE. AFTER ONE KEY CYCLE, RESET DTC P0107,P006B, PERFORM PPT E, AT STEP E9,AFTER VERIFYING MAP SENSOR CIRCUITES ARE OK, PERFORM HOTLINE ASSIST REQUEST,ADVISED TO CHECK EBP SENSOR AND TUBE FOR Details 3732241 TAP1 16 0 CRATER LAKE FORD LLC 35166 03-JUN-09 * TAP1 * 43547105 Customer Comments LOANER VEHICLE PROVIDED Tech Comments TAP1, EIGHT DAYS LOANER, WARRANTY REPAIR Details 6047397 E72 28 1.2 CRATER LAKE FORD LLC 57746 09-JUN-10 * RECAL * 45022301 Customer Comments CUSTOMER STATES THE TRUCK HAS LOST POWER, WILL RESET WHEN TRUCK IS TURNED OFF. Tech Comments DIAG UNABLE TO VERIFY.CHECKED OIL LEVEL USING SHORT STICK METHOD OK.FUEL QUALITY OK.PERFORMED SELF TESTS ALL PASS.RAN OASIS,NO ARTICLES.ROAD TESTED VEHICLE WHILE MONTERING PIDS.(DIST REGEN C)SAYS 251.67 MILES MGP 30PSI.VEHICLE ENTERED REGEN ON ROAD TEST AND TOOK APPROX 15 MILES TO COMPLETE.CHECKED BASE FUEL PRESSURE OK AT 7PSI,NO INTAKE RESTRICT OR EXH LEAKS.RECALIBRATER CONTROL MODULE PER HOTLIN Details 7473310 E72 39 1.6 MCSPADDEN FORD, INC. 69570 25-APR-11 7C3Z 6B209 D 09021501 Customer Comments BELT CAME OFF Tech Comments CHECKED AND FOUND TENSIONER DID NOT HAVE ENOUGH TENSION, REPLACED TENSIONER AND BELT, OK AT THIS TIME Details 7538879 P11 39 4 SHOW LOW FORD, INC. 69674 29-APR-11 8C3Z 8009 B 03358204 Customer Comments REPLACE COOLANT HOSES PER ESTIMATE Tech Comments REMOVED AND REPLACED LEAKING RADIATOR AND HEATER HOSES PER CUSTOMERS REQUEST. RJFROM CAC GAVE APPROVAL CODE M03X9 FOR $241.00 TOWARD HOSE REPLACEMENT AFTER HOSES WERE ALREADY REPLACED. MTIME 1.7 HRS FOR TIME APPROVED BY CAC Details 7563035 E72 39 3.2 SHOW LOW FORD, INC. 69674 29-APR-11 8C3Z 8575 D 03358203 Customer Comments CUSTOMER STATES THERE IS COOLANT LEAKING FROM THE TRUCK Tech Comments PRESSURE TEST COOLING SYSTEM, FOUND LEA FROM RIGHT HAND TANK ON THE RADIATOR. REMOVE THERMOSTATS AND CHECK AND MEASURE, 1.96 HYPER EXTENDED. FOUND TSB 11 1 7 FOR CONCERN AND REPLAC ED THERMOSTAT AND RADIATOR AND RETESTED, LEAK IS GONE. Details 7556981 11B24 39 .5 SHOW LOW FORD, INC. 69674 29-APR-11 * * * 03358202 Customer Comments RECALL 11B24 CONTINENTAL TIRE INSPECTION Tech Comments PERFORMED TIRE INSPECTION AND LF, LR, RR, LR ALL ARE A315 46U0 3809, SPARE TIRE P515 46XB 2907. REMOVED AND REPLACED SPARE TIRE Details 7538880 11B23 39 .5 SHOW LOW FORD, INC. 69674 29-APR-11 * * * 03358201 Customer Comments RECALL 11B23 POWERTRAIN CONTROL MODULE RCALIBRATION Tech Comments INSTALLED RECALIBRATION PER RECALL Details 7574200 11B24 40 .5 SHOW LOW FORD, INC. 69697 17-MAY-11 * * * 03391801 Customer Comments PERFORM RECALL 11B24 REPLACE SPARE ONLY Tech Comments REPLACED SPARE TIRE PER RECALL Details 8508964 E72 48 19.2 SAN TAN FORD 72436 16-JAN-12 3C3Z 6710 BA 12310801 Customer Comments C/S CHECK OIL LEAK AND CHECK COOLANT LEAK. ..................CONTINUED FROM TECH COMMENTS............. ...LINE FROM FRONT ENGINE COVER TO DEGAS BOTTLE Tech Comments VERIFY CUSTOMERS CONCERN. PERFORM OIL LEAK DIAGNOSIS. PINPOINT OIL LEAK COMING FROM THE RIGHT SIDE OF ENGINE BEDPLATE. REMOVE CAB FROM CHASSIS. BOTH FRONT CAGE NUTS SPUN AND MIDDLE CAGE NUTS SPUN. REMOVE HEAD LIGHTS AND NECESSARY INTERIOR COMPONENTS TO ACCESS. INSTALL ENGINE TO STAND AND PERFORM DISASSEMBLE TO ACCESS THE BEDPLATE. DURING DISASSEMBLY, FOUND TURBO CHARGER GASKET BETWEEN BOTH TURBOS Vehicle Information Report General Vehicle Information VIN: 1FTWW31R38EC23901Model Year: 2008Veh Type: TInv. Dealer: *Veh Line: T/F7 - F-SERIES OVER 8500 GVW [99-10]Market Derived: F - FORDDrive Code: T/E - 4 WHL L/H PART TIME DRIVEBody Cab Style: T/BC - DOUBLE CAB (CREW CAB)Version/Series: T/CD - 350 SERIESEng Serial No: 008070510126Body Shell: *Engine: T/QL - 6.4L OHV DUAL T/C V8 INTNL DSLTransmission: T/BE - 5 SPD AUTO 5R110W - HI/TORQUE Trace Trace Eng Serial No: EN100 2008070510126Trace Trans Serial No: A4522 140807A1B60534408C3P-7000-FC Build Information Region: NACountry: USAPlant: A1 - KENTUCKY TRUCK PLANT BUILDProd Date: 23-AUG-2007 Sale Information Region: NACountry: USASelling Dealer: 172407-*Selling Dlr St/Prov: ORBuyer St/Prov: * Arrival Date: 07-SEP-2007Sale Date: 22-FEB-2008Warranty Start Date: 22-FEB-2008Orig Warranty Date: 22-FEB-2008Red Carpet Lease: *Fleet/Retail/Co. Lease: RModified Vehicle: *Reacquired Behicle: *Vehicle Export Flag: N VOC/EOC : W318EC23901156JLXQ T32 19G2904 HGSE958B3LCMB2F91F6 4F68JM 4M D 356C078R92 Z1 3TA8S774 5 LR1FTW3 9 8 618A RBID Installed Option Information Air Conditioning: T/K - ELECTRONIC DUAL ZONE ATC A/CAlternator Amp Rating: 7EAudio Disk: * - [N/A]Axle Ratio: EGAJB - 3.73 FINAL DRIVE RATIOAxle Type: EGJAC - LIMITED SLIP REAR AXLEBattery Amp Rating: 5BBrake Code: FBAAJ - POWR 4-WHEEL DISC HYDRO BOOSTBrake Code (Service): * - [N/A]Calibration Code: 8F716A0AColor (Accent): * - [N/A]Color (Trim): 000HB - MEDIUM STONEDelivery Type: 0Driveshaft Code: *Front Seat: T/S - SEATS - INDIVIDUAL 40/20/40Fuel Type: AJ - DIESEL FUEL CAPABILITYGVW Code: GVW Class Code: WInstrumentation: * - [N/A]Mirror(Driver Side): BF - DRV ELECTROCHRO POW MEM MIRMirror(Psngr Side): * - [N/A]Paint: PNYW5 - OXFORD WHITE WB C/C-W/BPower Antenna: * - [N/A]Radio: ED - AM/FM STR/CD/CLK/NAVIG SYSTEMSound System: * - [N/A]Suspn Tandem Axle: Tire Brand: * - Tire Size: D3HBM - LT 275/70R18E A/T OWLTraction Control: * - [N/A]Wheel Base: Tire Dot Information LF: P51546UO????LR: P51546UO????LI: *RF: P51546UO????RR: P51546UO????RI: * Spare: P51546XB2907 ESP Information | Emissions Information ESP Code: *ESP Coverage (Miles): *ESP Coverage (Time): *ESP Plan Year: *ESP Signature Date: Emission Code: DGAAE-DGAAEEmission Cert Type: 5Emission Decal Suffix: RADEngine Family: 8FMXA064AGC |
Me too?
![]() VIN:1ftsw21p87ea81258 |
Thanks!
Looks like my radiator has been replaced a few times as well as my EGR coolers and valve. Seemed to of had DPF problems in the past with regen. Already bought my delete pipe though. |
wondering if someone can give me an oasis report on my truck?
vin=1FTWW31P55EB63873 thanx mike |
can you just get an oasis repot from a dealer for free?
Yes that's what I did this morning. No problems at all.
I just bought a 2008 f250 can you give me a oasis report on mine
1FTSW21R28EE25055 Thanks Dennis |
I tried to get one from my local dealer (not the one I bought from) and they claimed they couldn't give it to me because of privacy issues. I'm like
My opinion is they are just to freaking LAZY!!
