Egr delete - Ford Powerstroke Diesel Forum
Old 12-21-2012, 06:20 PM
Egr delete
Deleted egr h&s tuner. Does the wrench light stay in or am i missing something when i load the tuner?
Sent from my iPhone using AutoGuide.com App
Old 12-21-2012, 06:38 PM
You're going to have to explain what you mean. The first sentence is not a complete sentence or coherent thought.
You should not have a check engine light on if you did it right. If you haven't deleted your EGR and DPF, you should not be running the DPF deleted tunes.
Old 12-22-2012, 06:23 AM
I installed my h&s tuner, 4"turbo back, along with egr delete and coolant filter. When i first downloaded the program I received a wrench light for my egr. Reloaded hot tune and all is better.
Old 12-22-2012, 06:36 AM
Feedback Score: 9 reviews
Have you updated your tuner?
Old 12-22-2012, 06:40 AM
Not yet. Do I need to beings it was just purchased?
Old 12-22-2012, 06:47 AM
Most likely. They usually just sit in a warehouse until they need to be shipped. Keep in mind, the "Easy" tunes don't turn off the EGR, while the "Mild" and "HD" tunes do turn the EGR off.
Old 12-22-2012, 09:06 AM
Yep update your deal. Also don't freak if cruise don't work. I've heard of that happening . After a cycle or two of the key it is supposed to be cleared up
Old 12-22-2012, 03:08 PM
Took it for the first time on hot full power. Very nice. It was a little spooky with all the snow and ice, but i managed to find a few clear roads. My setup purchased from PTP worked great.
Old 12-22-2012, 05:36 PM
Feedback Score: 7 reviews
Have you pulled codes and actually seen what the light is on for?
Old 12-23-2012, 06:56 AM
The.code cleared when i switched from easy to hot.
