Brake tabs HELP!!! - Ford Powerstroke Diesel Forum
Old 12-17-2012, 08:15 PM
Brake tabs HELP!!!
I Did my front Brakes and forgot what tabs to use
Old 12-17-2012, 11:55 PM
What tabs?
Old 12-18-2012, 08:45 AM
When you buy new brakes it comes with clips how do i install those on 2009 ford super duty
Old 12-18-2012, 12:27 PM
The spring clips that attach to the ears on the ends of the pads?
They go on the pad before you load them into the mounting bracket.
Old 12-18-2012, 08:37 PM
Wink
are they needed...
Old 12-18-2012, 08:43 PM
Yeah it's a Turbo Diesel
Feedback Score: 8 reviews
I'd like to know too, doing my first brake job on this truck tomorrow. First time to do a super duty set of brakes.
Sent from my iPhone using AutoGuide.com App
Old 12-19-2012, 03:18 PM
You do need them, and make sure the little finger on the tab stays on the outside of the caliper.
This helps pull the pads away from the caliper. Also remember to apply a nice coating of caliper
Grease on the clips where they ride in the caliper. I just had some seized up in my truck.
Old 12-19-2012, 03:46 PM
Yes they really should be on there. Pads will be too loose without them.
Clean out the slot in the mounting bracket they ride in and put a thin coat of a good high temp brake grease in there to keep them from rusting up and getting seized.
Pay attention to the orientation of the clips when you replace them.
Bleed brakes with fresh fluid when your done too.
Old 12-19-2012, 06:48 PM
Feedback Score: 7 reviews
What he said about the orientation of the clips. They can be confusing so take one off at a time, find the right new one and pop it back into place.
