Arp head studs - Ford Powerstroke Diesel Forum
Old 12-17-2012, 06:35 PM
Send a message via Yahoo to sicwitted44
Arp head studs
Does anyone know if it is true that you can swap out ur head studs without using a new head gasket. Read that this not only can be done but can be done with the cab still on. Sounds to good to be true. Anybody have any experience with this?
Old 12-17-2012, 06:57 PM
The way these guys said they did this was by removing one factory stud then installed an arp stud , torqued that, repeated that step until all the stockers were replaced with the arp's. all of this done with cab still on.
Old 12-17-2012, 07:04 PM
There is a YouTube vid I think. I think it was some guys from a magazine. I've heard it can be done, but it takes some doing and you have to debt your firewall for one of the back studs I believe.
Sent from my iPhone using AutoGuide.com App
Old 12-18-2012, 04:01 AM
Send a message via AIM to blackcloud2k Send a message via Yahoo to blackcloud2k
Can be done but is tough. Also you can do this if you know for sure your stock HG is in good shape.
Old 12-18-2012, 05:08 AM
you fellas are saying that you can re-crush the head gasket??
wow... these oil burners really ARE different beasts... I can't tell you how many times I've tossed never ran head gaskets on a gasser away, because once they are crushed by torque, that is that... I can't imagine releasing torque on one bolt and simply replacing it, and expecting there not to be issues in that spot later on..
but- if this is true information- it's dang good to know!!
Old 12-18-2012, 05:21 AM
I personally wouldnt do it, but it has been done with no issues. If I were to do headstuds I am all about starting from scratch and retorquing them after several heat cycles to ensure that they are right.
Old 12-18-2012, 06:04 AM
I agree. If you are going thru the trouble of putting studs i would magnaflux and deck the head and put new head gaskets. I wouldnt do them one by one but thats just my opinion.
Old 12-18-2012, 07:00 AM
Did you retorque your studs after you had them on awhile?
Old 12-18-2012, 08:41 AM
I agree with you guys about it being ideal to do the whole thing if ur in there, new head gaskets, magna flux. But in doing that a whole lot more time and money are involved. That's why I asked about it on here. I figured if I could just drop six hundred on studs. Pull valve covers and have 8 or ten hours to kill it would be a cool cheap upgrade.
Old 12-18-2012, 08:56 AM
Been thinking about this....
At the risk of hijacking this thread, can I ask what part of the head gaskets are prone to blowing out on these things? ... I'm asking for a reason.. it seems if there is an issue with one area over and over, that one area could be studded in this fashion, and save hella time and money..
