How can i change the keypad code?
My brother has a 2008 FX4 and we were curious is to how we could reset the code to a code of our choice. we do have the factory combonation. i have tried to use the search bar but maybe i am just not wording this correctly. any help would be appreciated.
Right out of the owner's manual
Programming a personal entry code and keypad association to memory seats, mirrors and pedals To create your own personal entry code: 1. Enter the factory set code. 2. Within five seconds press the 1 • 2 on the keypad. 3. Enter your personal 5-digit code. Each number must be entered within five seconds of each other. 4. To associate the entry code with a memory setting, enter a sixth digit to indicate which driver should be set in a memory recalled by the personal entry code: • Pressing 1 • 2 recalls Driver 1 settings. • Pressing 3 • 4 recalls Driver 2 settings. • Pressing other keypad buttons or not pressing a keypad button as a sixth digit does not set a driver and will not recall a memory setting. Note: The factory-set code cannot be associated with a memory setting. 5. The doors will again lock then unlock to confirm that your personal keycode has been programmed to the module. Tips: • Do not set a code that uses five of the same number. • Do not use five numbers in sequential order. • The factory set code will work even if you have set your own personal code. Erasing personal code 1. Enter the factory set 5–digit code. 2. Within five seconds, press the 1 • 2 on the keypad and release |
Thanks for the help, it's not my truck or I would have checked it out.
No problem man, that's what the site's for.
