high idle mod - Ford Powerstroke Diesel Forum
post #1 of 7 Old 12-14-2012, 09:09 AM Thread Starter
sicwitted44's Avatar
Send a message via Yahoo to sicwitted44
high idle mod
anyone know a link that shows how to do the high idle mod for the #4 upfitter switch
sicwitted44 is offline
post #2 of 7 Old 12-14-2012, 09:14 AM
superduty6.4's Avatar
Should be able to just search it as 6.4 high idle mod and a bunch of info will come up.
Edit: just check out powerstrokenation in the 6.4 tech files. Its in there with pics. I tried to load up the link but it didn't work for me to paste it over here
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #3 of 7 Old 12-14-2012, 01:33 PM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
It's just hooking switch 4 to the PTO wire under your dash. 3 min mod...
Sent from my iPhone using AutoGuide.com App
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
post #4 of 7 Old 12-14-2012, 03:47 PM
What is the advantage to the high idle mod?
Code3F250 is offline
post #5 of 7 Old 12-14-2012, 04:02 PM
It brings the idle up to 1200 rpm as opposed to 1000 or whatever it is from the factory. Helps to avoid wet stacking if you do any extended idling. Also it enables you to instantly kick the idle up instead of waiting for the trucks computer to do it on its own.
08 F350 JOB 1
2.5" LEVELING KIT
CCV MOD
AFE CAI
PMF TRACTION BARS
post #6 of 7 Old 12-14-2012, 05:51 PM
It will actually kick up from 1200-2400 based on how charged your batteries are. If your batteries are low it will rev higher to charge them (of you are connected to the PTO wire).
-Tyler
Texas A&M c/o 2010
post #7 of 7 Old 12-14-2012, 06:12 PM
44magnum's Avatar
Quoted: 2 Post(s)
I just did this a few minutes ago,
I used the pto wire (yellow with green stripe) and attached it to my #3 upfitter (Supposedly Violet with green stripe, but the "green" stripe looked more Blue/Green to me) I used #3 as it is the lower amp of the upfitters. On an 08 at least IDK if it chaned over the years. https://www.fleet.ford.com/truckbbas...tml/q117r1.pdf
It really is easy to do, took me probably 8 minutes as it took me a while to find all the wires, I had never even looked at the upfitter wiring (or the other blunt wires) before. As none of mine were labeled, I had to google the wiring diagram to find the correct wires.
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
