TSB for coolant level? - Ford Powerstroke Diesel Forum
Old 12-11-2012, 06:19 AM
I was told there was a revision issued by FOMOCO that advised tech's to lower the degas bottle 'cold fill level' to just under the line.. is there any truth to this? I can see the TSB's here, but they aren't specific enough, and the oracle google is uncooperative while trying to nail it down..
do you fellas know anything about this?
Old 12-11-2012, 06:35 AM
I cant help you with the tsb but on the updated degas bottle the full line is lower than on my degas bottle. Hope this helps.
Old 12-11-2012, 09:05 AM
Correct, keep the coolant level on the min. when cold level and you will fine.
Old 12-11-2012, 12:43 PM
Thank you, gents..
Mine seems to maintain the same level no matter the temperature, and it is a touch south of the cold fill line..
There is some discoloration to the degas bottle above the fill level, and its from whitish at the top to brown near the bottom.. my deltas are at an almost constant of 4 degrees, and the oil is warmer than I would like to see at around 196~199.. I don't know whats normal for others, but thats what I see..
I've been holding out on a flush until ptp delivers the egr delete.. I figured I'd do the delete and the coolant filter along with flush all at once... The level of coolant hasn't budged since I've had the truck, but the discoloration and the deltas have me a touch concerned..
Old 12-11-2012, 12:52 PM
Your delta of 4* is completely fine. I see the oil temp, on average, anywhere between 196 and 199. Your oil temps seem normal to me
Old 12-11-2012, 01:50 PM
EGR delete back orders are shipping tomorrow, should have all the parts by then in to assemble the rest of the kits according to the tracking.
Old 12-11-2012, 02:09 PM
Very cool.. thanks Eric!! And thanks to the rest for the scoop as well.
Old 12-11-2012, 02:22 PM
You're welcome, if you need further assistant feel free to let us know.
Old 12-11-2012, 03:18 PM
No problem bud.
