coolant? - Ford Powerstroke Diesel Forum
Old 12-07-2012, 07:37 PM
Send a message via Yahoo to sicwitted44
coolant?
i just finished my egr removal and i filled the coolant system with napa 50 50 antifreeze. i,m wondering if i needed to use a special type of coolant or will i be ok with the napa?
Old 12-07-2012, 07:45 PM
Send a message via Skype™ to kendallcschm
it should meet the same standards as CAT EC-1 and it should be silicate and phosphate free otherwise all that bull**** will clog up your oil cooler, do you have a coolant filter? (probably a good idea). i would go with one of shells coolants or go to an international dealer to pick stuff up..
Old 12-07-2012, 07:55 PM
first time diesel owner, thanks for the advice. will i need to do a total flush now that i put the 50 50 in it? what do you suggest as far as a coolant filter?
Old 12-07-2012, 08:07 PM
Coolant filter either dieselsite or sinister and is the coolant you put in green? If so i would flush whole system with distilled water and perhaps maybe chemical flush then fill up with a cat ec-1 coolant(usually red in color).
Old 12-07-2012, 08:12 PM
yes it was green. guess i should have asked you guys first, saved myself some time and money. thanks for the info.
Old 12-07-2012, 08:18 PM
Here is a helpful link for flushing, the different ways and how much to add.
http://home.comcast.net/~lyon.family...ush%20v1-0.pdf
Edit: Sorry I thought it said 6.0
Old 12-08-2012, 10:24 AM
I'd do a chemical flush, make sure nothing is stuck in there.. and ayes a total flush, for a coolant filter kit i prefer sinister with a wix 24070 coolant filter.
Old 12-08-2012, 11:24 AM
Is there anything this detailed for the 6.4?
Old 12-08-2012, 04:07 PM
ok guys, did total flush today. im going to get on line and find that sinister coolant filter and get that on. flush cost me 8 hours and 160.00 dollars. will never make that mistake again.
Old 12-08-2012, 07:17 PM
Look no further:
Ford Coolant Filter System for 6.4 Powerstroke
