dual steering stabalizer issues - Ford Powerstroke Diesel Forum
post #1 of 8 Old 12-07-2012, 03:08 AM Thread Starter
Quoted: 36 Post(s)
hello- i put on dual stabalizers to combat the dreaded wobble. truck is a leveled 350 stock tires and wheels. the passenger side has blown 1 time and i replaced it and thought that the nuts from the link had hit it while cycling so i rotatated them to the backside for no clearence issues (the boot was ripped and the end of the shock had a ding on it and chipped next to the piston. i put the new one on and 3 months later a start noticing spots under the front end again and the wobble was back, i looked at the stabalizers again and the passenger side is leaking again- this time the boot is fine and i see nothing wrong with the shock but it is leaking around the piston for sure....... what is the culprit? i turned the wheel from lock to lock and nothing binds are hits??
gwilkrrs is offline
post #2 of 8 Old 12-07-2012, 03:32 AM
blackcloud2k's Avatar
Send a message via AIM to blackcloud2k Send a message via Yahoo to blackcloud2k
What shocks are you running? Could you have the wrong length shock on there maybe? The piston could be to long or to short for the application causing it to pull or bottom out at full lock either direction?
2015 F350 Ruby Red Platinum, SRW CCLB, Color matched Ranchhands, rigids.
SOLD:
blackcloud2k is offline
post #3 of 8 Old 12-07-2012, 04:35 AM Thread Starter
Quoted: 36 Post(s)
i bought the rough country dual kit. the part numbers matched up.......
gwilkrrs is offline
post #4 of 8 Old 12-07-2012, 04:41 AM
wilsonw2's Avatar
Quoted: 18 Post(s)
The problem is ur using cheap shocks. Upgrade to Bilstein and make sure the length is proper.
Sent from my iPhone using AutoGuide.com App
*NEW:
2016 F250 CCSB KR FX4
NL Fab:
---Stage 1 Intake
---EGR shmock off plates
---Flo Pro Exhaust (5" to 6" tip)
---SCT with GH tunes
---Waiting for first Fuel Filter change to install:
---------CCV Mod
---------CTS2 monitor with EGT Probe
Just passed 1,111.1 miles and LOVING IT!
**SOLD:
2010 F250 CC FX4
H&S
AFE Intake
and some other goodies...
wilsonw2 is offline
post #5 of 8 Old 12-07-2012, 04:49 AM Thread Starter
Quoted: 36 Post(s)
the four corners are supported with bilstiens- they may be better then rough country but i am confident this isnt the issue.
gwilkrrs is offline
post #6 of 8 Old 12-07-2012, 05:02 AM
I would also agree you have another issue at play here. Is your bracket mounted in the proper spot? Just throwing ideas out.
SOLD:
post #7 of 8 Old 12-07-2012, 05:10 AM
ZMANN's Avatar
Quoted: 1662 Post(s)
if they aren't over extending /compressing ( easy to check )
this second shock seems like it just lost a seal ,, it happens and that should be a warranty item if u bought it at a authorized seller IMHO
We Miss you Ronnie
ZMANN is offline
post #8 of 8 Old 12-07-2012, 06:12 AM Thread Starter
Quoted: 36 Post(s)
i turned the wheel and didnt feel or hear anything- i will have someone else turn the wheel while i watch and listen. i installed per the directions and think it was correct.
gwilkrrs is offline
