Ran this in my 6.0 will it work for my 6.4 - Ford Powerstroke Diesel Forum
post #1 of 24 Old 11-30-2012, 11:41 AM Thread Starter
Motorboy8769's Avatar
I mixed my fuel 50 50 with some fuel I got that they use in turbine engines from a buddy for free.... jp8 it is a really clean no 1 diesel I guess it ran fine in my 6.0 will it run in the 6.4??
Sent from my iPhone using AutoGuide.com Free App
2008 f-350 CCLB,
Rough country 4.5" radius arm drop lift
doc and Dpf delete
looney street from vivian
Motorboy8769 is offline
post #2 of 24 Old 11-30-2012, 12:04 PM
Doss's Avatar
Quoted: 17 Post(s)
It sounds like there's only one way to find out and only one person here with the stuff needed to do so.... you. LOL
Seriously though, I wouldn't put that stuff in the 6.4. There's no point in possibly destroying an engine when there's really no need to.
It may be your only purpose in life is to serve as a warning for others.
Doss is offline
post #3 of 24 Old 11-30-2012, 01:28 PM
08_Powerstroke's Avatar
Sounds like a big risk that could cost 10-15k real quick just because you got some free jp8.
08_Powerstroke is offline
post #4 of 24 Old 11-30-2012, 03:39 PM
It would probably work, but Uncle Sam doesn't really like it when you jack his fuel...
ZCLynch is offline
post #5 of 24 Old 11-30-2012, 04:00 PM
Eric@PTP's Avatar
Its really not recommended for high pressure common rail motors, it doesnt have the lubricant in it the pump or injectors will need, it also has a low cetane #, lower compression temp so cold starts will be a PITA, also due to the almost complete lack of sulfur in it your valve seats will be caked with soot over time, it will also prematurely wear out valve seats and seals. Mixing it with pump diesel wont add enough sulfur content back for lubrication and wont add enough cetane points.
All in all its just asking for trouble, in older diesels you can run it mixed with 2 stroke oil but just not in a common rail that has a $10,000.00 injection system. Its not a jet engine or a multi fuel engine so why risk several thousands to save a few dollars.
1-888-516-4644
GO NAVY
Eric@PTP is offline
post #6 of 24 Old 11-30-2012, 04:10 PM
You read the wiki article on jp8 didnt you
jackinggear is offline
post #7 of 24 Old 11-30-2012, 04:56 PM
screwatts's Avatar
Don't put jp8 in your truck.EVER
2006 F350 Reg cab 4x4 blacked out, ARP studs, EGR delete,Sinister coolant filter,Blue Spring,Edge CS,SCT with SPD, php hercules ,Zoodad, 4'' turbo back straight , 8" tip, airaid intake, 6" lift , billestiens,35's, 18's , 08 bumper , 08 tailgate , Harley Heads, Custom made traction bars.
screwatts is offline
post #8 of 24 Old 11-30-2012, 05:11 PM
havent you ever seen family guy? i think when you do that it makes the truck able to fly.
post #9 of 24 Old 12-01-2012, 10:34 AM
Doss's Avatar
Quoted: 17 Post(s)
I always laugh when people say they put jet fuel in their cars and "Boy, the car was really pulling hard... like a rocket."
Most of the guys that tell me those stories are older. I guess they don't know what jet fuel is and how it's formulated to burn in entirely different conditions.
Also, it's not nitrometh... you're not going to makes hundreds of horsepower more in a gas naturally-aspirated motor with the simple addition of "jet" fuel.
Yep, still holding the stance that this could end up being a $12-18,000 repair bill.
Doss is offline
post #10 of 24 Old 12-01-2012, 10:24 PM
Eric@PTP's Avatar
Nope, served in the Navy. Also have a Coast Guard buddy that ran it in his 6.0 . Trust me you don't want to run this stuff in a common rail motor.
1-888-516-4644
GO NAVY
Eric@PTP is offline
