Gunk on trans dipstick??? Pics - Ford Powerstroke Diesel Forum
post #1 of 19 Old 11-25-2012, 05:41 AM Thread Starter
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 18 Post(s)
Feedback Score: 12 reviews
So I was checking my Trans fluid yesterday and noticed it has some gunk on it... I wiped it off and checked it about 8 more times, each time there was gunk on the dipstick. Is this bad? I don't have any tranny problems, none at all.
Sent from my iPhone using AutoGuide.com App
2017 f250 platinum
Bone stock until warranty expires!
mts678 is offline
post #2 of 19 Old 11-25-2012, 06:03 AM
wilsonw2's Avatar
Quoted: 18 Post(s)
Not generally a good sign brotha. Do u monitor your tranny temps? I would drop the pan and change the fluid ASAP and see if its worse inside.
Black gunk usually means an overheated tranny. It might not be too late. But I'm no tranny expert.
*NEW:
2016 F250 CCSB KR FX4
NL Fab:
---Stage 1 Intake
---EGR shmock off plates
---Flo Pro Exhaust (5" to 6" tip)
---SCT with GH tunes
---Waiting for first Fuel Filter change to install:
---------CCV Mod
---------CTS2 monitor with EGT Probe
Just passed 1,111.1 miles and LOVING IT!
**SOLD:
2010 F250 CC FX4
H&S
AFE Intake
and some other goodies...
wilsonw2 is offline
post #3 of 19 Old 11-25-2012, 06:04 AM
ZMANN's Avatar
Quoted: 1776 Post(s)
no bueno
get that looked into ASAP
looks like friction material ?
your lucky the 08.5's up have a real filter in the pan otherwise your solenoids would be crying
We Miss you Ronnie
ZMANN is offline
post #4 of 19 Old 11-25-2012, 06:08 AM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
Something ain't right..... Is that all that shows up when you check it or is there actually red fluid?
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #5 of 19 Old 11-25-2012, 07:09 AM Thread Starter
mts678's Avatar
Quoted: 18 Post(s)
There's fluid on the dipstick, it's at the correct level. But the gunk is not black it's more like dried-up tranny fluid.tranny temps are at 156 normal driving
2017 f250 platinum
mts678 is offline
post #6 of 19 Old 11-25-2012, 08:23 AM
travisH3's Avatar
Quoted: 2 Post(s)
I'd be getting trans fluid and dropping the pan.
T-rav
2010 F350 6.4-
travisH3 is offline
post #7 of 19 Old 11-25-2012, 08:34 AM Thread Starter
mts678's Avatar
Quoted: 18 Post(s)
Yeah, that's the plan early this week. Anybody have the tranny filter replace how to thread handy? I've seen it before but I'll have to dig it up if nobody has it handy
2017 f250 platinum
mts678 is offline
post #8 of 19 Old 11-25-2012, 09:06 AM
Clayton1985's Avatar
You're ok. Your trans is fine. It is just crud in the dipstick tube, myself and many others have the same thing.
Just last saturday I had to change my TFT sensor which required dropping the pan. I also changed the filter. Not a spec of dirt/crud, it was spotless. I was going to take some pics but it was -25 and i was doing it in my driveway, my hands were cold enough nevermind holding a camera!
Just pull the filter straight down to remove, check for the hard rubber seal from neck isnt stuck up inside and install new filter. I re-used pan gasket, the filter I got did come with a new one however.
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
post #9 of 19 Old 11-25-2012, 09:27 AM
Tsgs69400's Avatar
He Is correct guys. I had the same concerns 2 years ago when i checked mine. I took it to my dealer shortly after and the tech informed me that many dipstick tubes were not painted/coated on the inside. Thus any moisture will condensate inside the tube and cause rust. They flushed the trans and changed the fluid for me none the less as a sign of good faith.
He just said to take the tube off sometime and flow some paint through it.
Thad
2008 f-350 CCSB 4x4 6.4 Lariat Spartan Tuned, MBRP Duals, S&B intake, egr delete, ccv delete,custom coolant bypass, RF amps, Infinity Component Spkrs, Pioneer Shallow Sub, 13.9sec best
1996 f-250 Extended cab Short bed 4x4 7.3 5-spd, D60, Diamond Eye4" duals, DP Tuner, Stg 1 Injectors, DIY Intake, Custom Regulated Return Fuel System, Adrenaline,billet ww,Comp 910 springs, D66 Turbo, 6.0 Intercooler, SD rear springs,Custom trac bars, Truetrac diff.
Tsgs69400 is offline
post #10 of 19 Old 11-25-2012, 09:56 AM
wilsonw2's Avatar
Quoted: 18 Post(s)
I'm no mechanic but I would still get it checked.
*NEW:
NL Fab:
---Stage 1 Intake
---------CCV Mod
**SOLD:
2010 F250 CC FX4
H&S
AFE Intake
wilsonw2 is offline
