2010 KR - Sign The Deal?
I am out in Afghanistan but spending my free time looking for a new to me F350. I ran across this 2010 F350 King Ranch and it seems like a REALLY good deal. What do you think?
2010 F350 King Ranch CCLB FX4 / 80k Miles / White Platinum Metallic Tri-Coat Over Tan / Carfax says 1 or 2 Owner and No Issues 30K + TTL = 32K OTD OASIS & CarFax Info: 677 Miles Engine Noise & Check Engine Light #8 Valve Broken Replace Head M Time To Remove Cab Bolts Valve Stuck In Head Bent 2 Push Rods & Valve Tappets Came Apart 17.5 Labor Hours 6000 Miles Oil & Filter Replaced 12750 Miles Oil & Filter Replaced 21000 Miles Oil & Filter Replaced 25000 Miles Leaking Coolant Pressure Tested - Replaced Both O-rings and Clip on Upper Radiator Hose 1.1 Labor Hours 32500 Miles Air Filter Replaced Fuel Filter Replaced Oil & Filer Replaced 54500 Miles Leaking Coolant Pressure Tested - Radiator Leaking - RR Radiator 2.75 Labor hours 54500 Miles Oil & Filer Replaced 62000 Miles Oil & Filer Replaced I have a mechanic I found on Craigslist going to take her for a test drive in a few hours. I am hoping he gives her an AMAZING or PIECE OF CRAP rating so the decision is easier. Would you sign the papers and send the check? |
First off thanks for your service !! Looks pretty good , i would be concerned with the amount of fuel filter changes ,there should have been 4or 5 fuel filter changes? maybe find out if he serviced them his self or had another shop do them?
I wouldn't touch it
Id stay away...the valve and push rods issue concern me
those issues were 60,000 miles ago
I think it proved itself fixed IMHO |
i woudlnt mess with it either
I would try and find a better truck and stay away from that one for sure. Don't want to get yourself into a huge mess.
Sent from my iPhone using AutoGuide.com Free App |
Try again. if it had lower miles would be better...
price isnt bad, but my 09 with 29k loaded lariat was listed at 35. and didnt have any of those engine problems. |
Well the responses seem to be about 2/3rds negative. I wonder if I could get more details about the engine issues from the Oasis? It seems like the isuses were fixed with less than 1k on the clock, 80k miles ago. Plenty of trips to the dealer since then but no mention of engine issues.
This was about the best deal I had seen for an 08-10' KR anywhere. If anyone has seen a decent deal on a CCLB 4x4 (2002-2010) let me know! Thanks for all the help. GM |
not sure how far your looking to travel but theres a 05 CCLB dually lariat fully loaded immaculate condition in ny pretty close to the nj border with only 16k MILES! the thing is mint and hes only asking $30k Mint rust free 05 F350 Crew cab Dually diesel 16KM for vintage car
