08' Tail light LEDs - Ford Powerstroke Diesel Forum
post #1 of 14 Old 11-20-2012, 10:00 PM Thread Starter
08' Tail light LEDs
Anyone just replaced their tail light/brake and turn signals with LED lights? I'm sure a flasher or resistor may be necessary, but wouldnt it be a simple thing to do? I put LED lights in for the license plate, dome light, reverse lights etc already. Is it the 3157 bulb for the tail light/brake ?
2008 Black F250 6.4 - Long Bed XLT
8" Fabtech, H&S Mini Maxx (Hot Damn), 4" aFe Exhaust, Downpipe, Cold Air Side Pipe, aFe Intake, Flo-Pro Emissions Delete
BigNiner19 is offline
post #2 of 14 Old 11-21-2012, 12:35 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
3157 bulbs are correct.
You can either add resistors or you can take the truck in to the dealer and have them reprogram the computer for leds. 2008 and up superdutys don't use a standard flasher.
Here is my truck with 2010 tail lights and leds in the daytime:
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #3 of 14 Old 11-21-2012, 01:31 AM
HarvestingInternationally's Avatar
looks good what kind of bulb is that
http://img716.imageshack.us/img716/2580/oppt.jpg
2006
F250 Crew Cab Long Bed 6.0 TurboDiesel FX4
Diesel Site Coolant Filter, Edge Insight CTS, BPD FICM 48v, Metal CAC Tube, Blue Spring,Sinister Diesel EGR Delete w/ Up Pipe, Riff Raff Boots, MBRP 6212-409 Exhaust, BFG AT's,
Bilstein 5100's with Leveling Kit, ISSPRO EV2 Gauges (Pryo
, Fuel Pressure)
Eric
HarvestingInternationally is offline
post #4 of 14 Old 11-21-2012, 07:08 AM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
so there is no way to put in an LED flasher relay for 08 and newer, i was wanting to order LED's for the front turn signals but dont want to mess with wiring, splicing in resistor.
BTW, i believe his LED lights are from V-leds.com
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #5 of 14 Old 11-21-2012, 09:17 AM Thread Starter
You think there would be any issues bringing a "tuned" truck and having them reprogram the computer for LED's? I have an H&S tuner installed on my truck and dont want that to get messed up.
I'm surprised I havent read anything more about people trying to do this. If all the trucks are capable of being programmed for use of LED's where you could swap all your incandesent lights for LEDs without splicing into any wires, it seems like a no brainer!
post #6 of 14 Old 11-21-2012, 09:27 AM
Doss's Avatar
Quoted: 17 Post(s)
Why wouldn't you want to go through the trouble of adding a resistor? It's dead simple and if you mess up the wiring doing that, you need to stay away from DIY mods on your truck altogether.
That's the route I'd take to adding LED turn signals (and it's what I did for my front signals). I run an LED reverse light as well.
It may be your only purpose in life is to serve as a warning for others.
Doss is offline
post #7 of 14 Old 11-21-2012, 01:54 PM
travisH3's Avatar
Quoted: 2 Post(s)
I don't want a bunch of splices in wiring. That's all. I just like the simplicity and cleaness of the flasher relay but if u can't do that with the 6.4 I guess I will have to look into something else
T-rav
2010 F350 6.4-
travisH3 is offline
post #8 of 14 Old 11-21-2012, 08:32 PM
if anybody has added led tail lights, please post pictures, im thinking about adding the whole tail light lens and would light to see pictures of guys that have already done it
McChicken is offline
post #9 of 14 Old 11-22-2012, 09:02 PM
cypher0807's Avatar
Go RECON for the tail lights, 299 and no splicing! And whatever you do, DO NOT buy led bulds no matter what size you need from them or any other i.e Summit, Jeggs etc. Ebay sells them a hell of a lot cheaper. I've had mine for over 4 years without problems.
Proudly STILL serving!!!
cypher0807 is offline
post #10 of 14 Old 11-23-2012, 02:05 AM
h1gg1n5's Avatar
I wished I saw this thread before I bought my recon products.....
RECON LIGHT/PARTS= CHEAP JUNK!
2008 F450 CCLB KING RANCH
H&S Mini Maxx w/ Gearhead Tunes | DPF & EGR Removed | Downpipe | CAC Pipe | CCV Mod | Injen CAI |Dieselsite Coolant Filter & Boots| Mishimoto Rad | BFC Headlights
h1gg1n5 is offline
