Ordering parts? - Ford Powerstroke Diesel Forum
Old 11-20-2012, 07:47 AM
Ordering parts?
Ok so I have to do head gaskets, of course I'm going with studs and I see a lot of kits that are just the head gaskets and studs is that saying you do not need any other gaskets but those? Also while I'm in there what else can I do to prevent this from happening again. I already have an egr delete and dpf delete. I run an h&s mini maxx on the mild setting most of the time and a few times on the wild setting.
Old 11-20-2012, 10:06 AM
Make sure you use OEM gaskets. Also make sure the heads are decked and mgnafluxed.
Old 11-20-2012, 10:07 AM
7.3 4 Ever! Nothing else!
Feedback Score: 7 reviews
^ AGREE!
Old 11-20-2012, 10:12 AM
Feedback Score: 5 reviews
Old 11-20-2012, 01:35 PM
The heads are getting milled while their off and gaskets I would not use the other one oem going back on but all gaskets do I need besides head gaskets?
Old 11-20-2012, 01:38 PM
Exhaust manifold and intake manifold gaskets
Old 11-20-2012, 03:38 PM
valve cover and turbo gaskets.
If your headgaskets are still good I would suggest doing them one at a time.
If you pull heads, you have fuel lines and other associated parts to replace as well.
You save at least $300-500 in factory parts if you do studs one at a time.
Old 11-20-2012, 03:39 PM
I have an entire top end kit that gives you all the gaskets amd seals to get the job done
Old 11-20-2012, 07:23 PM
I have to pull the heads because of blown head gaskets, so doing them one at a time is not an option. I figured I needed all the gaskets but this is my first diesel head gasket job. I just could not understand why they would sell the studs and head gaskets as a kit with out the rest of the gaskets.
Old 11-21-2012, 01:13 AM
There's a parts list on the nation.
