Reinstalling h&s mini max
When the shop that installed my tuner installed it they didn't turn on my low boost fuel adjustment. How would I reinstall my tuner and turn it on?
Technically, it was already set. Keep in mind, they had an option of setting it from 1-5 with default being 3 if they didn't change it. So it is installed, just at the default value.
Sent from my LTEVO using AutoGuide app. |
I mean, how would I reinstall the tuner to where I could adjust it?
Go through the download process again. Turn on the ignition, go to menu on the tuner, select install download, then follow the instructions. You will have to cycle the key on and off once but it will tell you when to do so.
Exactly, just plug it in, turn the Jerry to the on position and select the Download option. You'll be prompted at a certain point.
