Is it safe to wash engine bay - Ford Powerstroke Diesel Forum
Old 11-14-2012, 11:48 AM
The engine bay on My 2010 is getting pretty dirty. as this is my first diesel can I spray it with engine cleaner and hose it down. did it twice a year with My gassers and never had any problems. is it safe?
Old 11-14-2012, 11:51 AM
Take the same precautions as you did with your gasser and there probably won't be a problem. As usual, do not spray electronics or electrical parts (especially the batteries or alternators).
Also, do not spray the engine when hot. I know a lot of engine cleaners say to get up to operating temps, but I don't use those. Too many hot iron pieces that will crack if you cool them too quickly.
Usually, I just spray the engine with some power cleaner/degreaser and wipe it down instead of hosing it. It'd have to be caked in mud before I hosed it.
Old 11-14-2012, 06:26 PM
Just don't use high pressure, do it cold, and keep it away from electronic goodies along with that air filter.
Old 11-14-2012, 09:12 PM
I spry simple green and hose it down cold a few times a year and it looks like new.
Sent from my DROID2 using AutoGuide.Com Free App
Old 11-14-2012, 09:25 PM
Feedback Score: 3 reviews
On my 6.0 I have always just coated everything with ZEP Indistrial Purple Degreeser (Home Depot) and hosed it down. Alternator, batteries, everything. Done it hot and cold and never had any problems.
I am not recommending that you do this but thats just my 0.02
Old 11-15-2012, 05:11 AM
To those saying not to wash it down while hot, what do you think happens in a heavy rainstorm?
I leave my truck running while I wash it and have never had an issue with pressure washing but I do take it easy unless I have a mud caked part that needs it.
Old 11-15-2012, 05:24 AM
I've seen, with my own two eyes, jugs (moto cylinders) pop like corn when hot and hit with a cold hose.. I've never seen it happen when they were running, though.. I guess, (and this is only a guess) the heat displaced is a lot quicker when it's not running..
as far as cleaning an engine bay, I've gone as far as to make a paste of comet and water, 'paint' it all over the engine bay, let it sit until almost dry- and wash it off with low pressure and a brush.. it works like a charm.. it would be a pita to attempt that on these cramped engine bays, though..
avoid electronics like the plague, though.. I usually plastic and duct tape those when I do these things.
Old 11-15-2012, 05:41 AM
In a heavy rainstorm if I pull into a fuel station and pop the hood to check oil ETC the motor isn't soaking like I ran a hose on it,,
I personally use a high pressure but stand back so it just power mist the engine ,, that uses a lot less water than a garden hose at 60 PSI,, but mostly I just wipe it down with a cleaner
Old 11-15-2012, 05:59 AM
Yeah it's a Turbo Diesel
Feedback Score: 8 reviews
I put mineral spirits in a hand pump spray bottle, works great
Sent from my iPhone using AutoGuide.com App
Old 11-16-2012, 03:51 AM
I agree with that. Im not saying to run a cold water hose over the engine while it is hot. I also just use a power washer from a few feet away so its more of a power mist, still works quite well.
