Fuel cooler coolant and nitrates... - Ford Powerstroke Diesel Forum
Old 11-07-2012, 10:48 AM
Is it needed to maintain nitrate levels in the ford yellow or "gold" coolant in the fuel cooler...if so my math says it takes 1oz of DCA4 per ~30-31 oz of yellow coolant (quart-ish) to bring it to within spec (if nitrates are in the 300-800ppm range)...so does this sound right? Can't find a solid answer on this...
Thanks in advance...
Sean
Old 11-07-2012, 01:14 PM
I tested the coolant and it was good, but I also see I have orange coolant in my truck...
I tested that and everything was good except nitrates...came in a little low...can I add fleetguard dca4 to orange coolant? Don't know if it is ford orange or?? Just bought this truck...
Old 11-07-2012, 01:31 PM
either way id get that orange coolant out....unless its red cat but orange get it out
Old 11-07-2012, 01:51 PM
yea i would get the orange coolant out. It should either be the ford gold or elc red. The nice thing about the cat elc is no nitrates or silicates.
Old 11-07-2012, 04:15 PM
Is there any accurate way to tell if this coolant is red elc?
Old 11-08-2012, 06:35 AM
Probably not without having it tested by a lab.
Old 11-08-2012, 03:27 PM
Called the dealership, they used prestone universal extended life antifreeze...so I think I am good, besides the fact I need to add some dca4 to bring it into spec....
