CAC pipe fittings leaking, how do I fix the issue? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 10-29-2012, 07:04 PM Thread Starter
I've replace my stock CAC pipe with a Flow Pro CAC pipe. I've noticed that it's leaking where it hooks up on both ends of the pipe. I didn't replace the rubber coupling that mates the pieces together. What can I do to fix this issue, I'm afraid of over tightening the clamps and breaking something. Are there better after market rubber couplings that I can use or get new OEM ones? The ones that are on there now look like there in good shape. I noticed that it's always leaked a little on both ends of the CAC pipe prior to installing the new Flo Pro pipe. Also is the residue that is leaking out of the CAC pipe oil? Any advice or suggestions would greatly be appreciated. Thanks!
brkncly is offline
post #2 of 11 Old 10-29-2012, 07:23 PM
44magnum's Avatar
Ya its probably oil leaking around the boots (rubber couplers), its nothing to worry about, many guys do a CCV mod to vent the oil into a catch can or onto the road. Search CCV mod if you don't know what that is.
Also you can tighten the clamps pretty good, compress the spring a bit, I'm sure there are tq specs somewhere but don't worry about over tightening, you would be hard pressed to hurt anything.
2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5 PMF traction
Please collect and message me Shell, Rotella oil cap codes aka "my miles matter" I'm trying to save up for a hat or something.
44magnum is offline
post #3 of 11 Old 10-30-2012, 07:23 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
If you are looking for upgraded boots dieselsite makes some. They are more oil resistant than the OEM ones. They are a nice upgrade.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #4 of 11 Old 10-30-2012, 07:41 AM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
I would suggest the CCV first as well...
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
post #5 of 11 Old 10-30-2012, 09:53 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I would also recommend the ccv mod.
08 F350 cc/sb 4X4
post #6 of 11 Old 10-31-2012, 08:58 PM
44magnum's Avatar
According to Dieselsite, tq specs on the spring clamps is 60 IN/LBS. And I would also recommend either a CCV mod or boots that will not degrade because of the oil. The dieselsite ones are oil resistant, I have them and they are very high quality. http://www.dieselsite.com/ford64ldie...tebootset.aspx
44magnum is offline
post #7 of 11 Old 10-31-2012, 10:27 PM
SickStroke6.0's Avatar
Feedback Score: 9 reviews
Have any of you guys used 6.0L boots on a 6.4L? They are a tad bigger and would allow a little more room to install the aftermarket CAC pipes. I know my stock boots are just barely on there.
Blake
2013 F-150 CCSB Oxford White FX4 EcoBoost
Loaded with every option...
2008 F-250 CCSB Dark Copper King Ranch 6.4L FX4
4" MBRP Exhaust w/ Muffler (DPF/DOC Delete), Modded Stock Intake, H&S XRT Pro
SickStroke6.0 is offline
post #8 of 11 Old 11-01-2012, 07:46 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I had the same problem with the stock boots. They were barley long enough. The 6.4 dieselsite boots are longer than the OEM boots and fit better.
08 F350 cc/sb 4X4
post #9 of 11 Old 11-01-2012, 01:09 PM
44magnum's Avatar
Well unless you could get a set of 6.0 boots real cheap I would just get a good set of aftermarket ones, the dieselsite ones are considerably longer, I have room to double clamp mine.
44magnum is offline
post #10 of 11 Old 11-01-2012, 01:12 PM
I have like three sets of 6.0L boots laying around.
Blake
