Battery light on? Confused. - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-18-2012, 02:13 PM Thread Starter
Djones's Avatar
My battery light has been on for the last two days. When I turn the truck to "on" position the volts read 12.2 from mini maxx. When I start it the volts are at 12 then about a minute later or so it jumps right to 14.3-14.5.. But the light remains on. Anyone have any ideas what's up? Or how I can test for potential problems?
Thanks.
Sent from my iPhone using AG Free
08 King ranch, H&S Mini Maxx, 5'' Exhaust, DPF/EGR Delete- 20'' wheels on 35's.
Djones is offline
post #2 of 4 Old 10-18-2012, 02:34 PM
Doss's Avatar
Quoted: 18 Post(s)
Do you have dual batteries? One could be bad.
Also, just because it reads 12+ V doesn't mean it holds that under a load (such as starting an engine). Go get them checked.
It may be your only purpose in life is to serve as a warning for others.
Doss is offline
post #3 of 4 Old 10-18-2012, 02:53 PM Thread Starter
Djones's Avatar
Yeah I have two. A friend has a meter we're going to test them.
Djones is offline
post #4 of 4 Old 10-19-2012, 07:05 AM
Doss's Avatar
Quoted: 18 Post(s)
Is it a load tester? Don't just read the voltage. That doesn't tell you much. Any of the autoparts stores should have a load tester they can hook up to the batteries without having to remove them from the truck.
Doss is offline
