Brake Clips -- 2008 F250 6.4L King Ranch - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-07-2012, 02:40 PM Thread Starter
Let me just say, whomever at Ford that designed the brake clips for holding
the brake pads ought to be fired.
I don't know about ya'll, but getting new pads back on with this clips is
utterly difficult. As such, I just used (1) clip on each pad in the forward
direction of spin. I doubt that braking in reverse will give me much trouble.
alby is offline
post #2 of 6 Old 10-07-2012, 05:20 PM
ATVJOE's Avatar
Did you get the Motorcraft replacement pads? Did mine about 2 weeks ago and seemed to go together okay, I used the original equipment pads as they last forever.
2008 F250 SD King Ranch 4X4, H&S Mini DPF delete
Job 2 LB SRW Crew Cab AMP Power Running Boards
ATVJOE is offline
post #3 of 6 Old 10-07-2012, 05:30 PM Thread Starter
Nah.. I got the Centric Premium Semi Metallic Disc Brake Pads
Centric Centric Premium Brake Pads - Semi Metallic - JCWhitney
alby is offline
post #4 of 6 Old 10-08-2012, 08:08 AM
Doss's Avatar
Quoted: 18 Post(s)
Hopefully you didn't get the ones you linked to (for GM).
I would've bought the OEM ones myself. I've learned not to trust any of the other brands unless they are track proven (I run Hawks on my Cobra for track work). Not saying these (Centric) aren't any good, I just haven't heard of them before. When stopping an 8000+ lb truck or 20,000+ lb truck and trailer combo, I trust Ford did their homework.
Also, why are you getting mad at Ford because non-Ford pads don't fit? Sounds like you should be mad at Centric to me. I've put aftermarket pads on lots of cars and sometimes they just don't fit. Exchange them for a new set and then they do. Quality control seems to be the issue.
It may be your only purpose in life is to serve as a warning for others.
Doss is offline
post #5 of 6 Old 10-08-2012, 09:37 AM
srjd's Avatar
Quoted: 2 Post(s)
Surprisingly the oem pads are probably the best ones you can get. Lots of people have had problems running other pads
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #6 of 6 Old 10-08-2012, 10:33 AM Thread Starter
The pads themselves fit, it's just the clips on the ends of the pads that
don't appear to be user friendly. The clips look exactly like the OEM pads
I took off the truck. But getting them back on with "both" clips was just
beyond me. If you got one side of the pad, the other didn't want to go
on. Just strange. When I say "on" I mean a pad loaded with block clips
trying to be placed into the notches on the caliper shoe, before I've
put the caliper back on.
All in all, it works fine with one clip per pad, because I gave up on using
2 clips do to the difficulty in getting them to fit back into the notches
on the caliper shoe. Otherwise, everything else was a easy as pie.
alby is offline
