trailer/truck park lites 2008 f250 6.4 - Ford Powerstroke Diesel Forum
Old 10-01-2012, 09:40 AM
got no running lites on trails west horse trailer [goosenek]....used to work...the park lites on the truck work....but the brown wire at bumper outlet wont power up...all the other lites on trailer work..stop,turn etc ... anyone know if there is a separate fuse for running lites on the trailer fusebox on trailer ?
I CANT FIND THE FUSE BOX IN THE PAX SIDE FOOT WELL....PULLED THE PANEL OFF FOR FUEL CUTOFF BUT MY EYES CANT SEE THE FUSE CONTAINER [which ford book says is on the passenger side.
stuck 2500 miles from home and kinda running illegal at night.
appreciate the help
Old 10-01-2012, 12:08 PM
I dont know the answer for the question about the seperate fuse but the fuse box is on the pasenger side on the floor where you put your feel. You have to pull off a cover and underneath that is another black cover for the fuse box. The fuses are under there. Hope this helps
Old 10-01-2012, 12:19 PM
There's also a fuse/relay panel under the hood near the brake fluid reservoir. Test all your fuses at the passenger floor board first and then try under the hood. You can check all of them in about 3 minutes.
Old 10-01-2012, 03:43 PM
thanks for thr replies....found the pax fuse box......was expecting a big door like the 7.3 ....wiring probs are in trailer and truck is good.
Old 10-02-2012, 05:56 AM
My trails west actually has a fuse panel in the dressing room too. If yours does, might check there too.
