Steering woes since cab off repair
I had my cab off to repair a leaking bedplate. Since it has been repaired, there is a clicking sound /sticking spot in my steering - any ideas on where to be looking? The repair was warranty, so it will be back to the dealer but wanted to try narrow things down a bit so we can resolve quickly. It was perfect before repair, but the minute I drove it off the lot I could feel something wrong - I would swear its like a bent column?? The tight spot (for a lack of a better term) isnt always at the same place in steering wheel rotation...
I have been experiencing the same issue. I can not pinpoint what is causing it.
I swore my steering felt tighter after my cab off repairs. I did find out that I had a bad tie rod end which was some of my problem but the steering still doesn't feel 100 percent right.
check your pitman arm.. it could have not been tightened back on tight enough if they had to remove it. just a thought
I heard a lot of times they will accidentally bend the steering rod from the firewall to the steering box.
My sticking happened after I did my EGR delete. I disconnected the steering to allow me to get the cooler out, when I put it back together it has a stick to it. I dont think I bent anything....
I havent done any work on mine myself in that area - did you disconnect the coupler?? Is there any room for error on re-assembly??
yes I disconnected it at the coupler. There is really no room error when putting it back together, it will only go back together one way.
Never heard of anything like this. The shaft is disconnected in one spot and a couple hydroboost lines are disconnected. Is it possible there might just be some air in the power steering?
I had taken mine back to be bled right after the problem surfaced but to no avail. The gearbox has been changed now too and the problem persists!
