All I Wanted Was an Oil Change - Ford Powerstroke Diesel Forum
post #1 of 35 Old 06-30-2012, 03:46 PM Thread Starter
Alberta Advantage's Avatar
Quoted: 19 Post(s)
Took my '09 F350 in for regular maintenance, has 56,208km on it or about 35,000 miles, and found out that I needed brake pads and my rotors turned, my DPF is blown, my aftermarket Bilstein steering stabilizer/damper is leaking, my track bar bushing is toast and that I need a new drag link and trackbar. DPF is covered under warranty but the drag link and track bar aren't. Just missed warranty coverage by a couple of months.
Any suggestions for an aftermarket drag link and track bar? I don't think I need to replace the entire track bar as it just seems like it's the bushing but there wasn't a front end guy at the dealership today to confirm. Also, track bars don't seem to be too expensive. See BD Diesel's retails for $250. Been eyeing some PMF stuff but am open to opinions and options.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #2 of 35 Old 06-30-2012, 04:34 PM
cbenn's Avatar
Quoted: 2 Post(s)
PMF you just can't go wrong with Trevor!
Just purchased a new 2016 CC
SOLD
2008 F350 CC SRW, 4X4/LB
Spartan Tuned/Spartan TCM
1722 Elite Head Studs/ChromeMoly pushrods
Bullet Proof 1/2 oil cooler kit
4" Down Pipe/4" DPF/Cat Delete
Diamond Eye 5" DPF back/5" Areo Turbine Muffler
3" CAI/inter cooler
S&B-CAI
CCV mod w/catchcan
Big Wig Sway Bars
PMF Traction bars
Icon 2.5 front coil springs
Bilstein shocks/Top Gunz dual stabilizer w/Bilsteins
Airlift/remote airbags
Viper 5701 w/SmartStart
cbenn is offline
post #3 of 35 Old 06-30-2012, 04:51 PM
What do you do to that truck!?!? I have 114k miles on original brakes and had 107k on the factory dpf and very rarely tow. And when I do its a snowmobile trailer
Sent from my LG-P509 using AutoGuide.Com Free App
08 CC SB
Fun Stuff
Mini Max / S&B Intake / 4" MBRP DP / 5" MPRP DP Back / 5" x 6" x 18" MPRP BLACK Tip
Normal Stuff
10" shallow RF sub w/ custom box & amp rack / Xtant 600W amp / Tinted front windows to match factory rears / Recon bed lights
08SuperDiesel is offline
post #4 of 35 Old 06-30-2012, 05:06 PM Thread Starter
Quoted: 19 Post(s)
Think that's what I'll probably end up with as I can get the drag link and track bar now since I need to replace the OEM parts and then, once I decide what size lift I want, I can get his 4-link system and a set of floating traction bars when the time's right. My biggest issue is getting this stuff. I understand that they're swamped with orders and delivery time is 2-3 weeks and shipping on this stuff is expensive to Canada! Might have to send him an email or phone him and see what I need.
I just drive my truck to and from work. Don't tow anything too heavy and don't have anything too heavy in the bed. The track bar bushing is what's failing right now according to the vehicle report card. In the comments section, it says "drag link at pitman arm feels off." Don't know what that means as I picked my truck up 5 minutes before they closed. Have to go back Wednesday for a new DPF and will find out more about my steering axle issues. Brakes seem to go out on all the vehicles I own. I had to get new brake pads and my rotors turned on my Infiniti last month which has less than 30,000km on it! One of the rotors was warped on my G37. Might be the way I drive. I do drive a large amount in the city so do lots of stop and go driving. Don't do too much highway driving.
Putco Window Visors
Line-X
Bak Flip F1
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
4" Solstice Prime
Truck Bed Lights
post #5 of 35 Old 06-30-2012, 06:03 PM
Quoted: 48 Post(s)
I'm sorry, but I don't let anybody sell me maintenance that I don't ask for.
If they point it out and you confirm on your own and agree that there's an issue? fine...
drunk on diesel is offline
post #6 of 35 Old 06-30-2012, 06:06 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 270 Post(s)
my factory brakes lasted till over 90k
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #7 of 35 Old 07-01-2012, 01:24 AM Thread Starter
Quoted: 19 Post(s)
I knew I needed my brakes done as I was told at the previous service that I'd probably be due for pads at my next service so that wasn't a surprise. But I told the service writer at my previous maintenance interval that I had ongoing issues with death wobble and that it was getting a lot worse. Wasn't able to just ride it out anymore. The truck would wobble/shake so vigorously, I'd have to slow way down to regain control. Was told everything was within Ford's spec. Today, was advised I need a new track bar and drag link. Don't know how it ended up from everything in spec to needing two new steering components in 5000 miles...
Putco Window Visors
Line-X
Bak Flip F1
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
4" Solstice Prime
Truck Bed Lights
post #8 of 35 Old 07-01-2012, 05:32 AM
dazed01's Avatar
Do you have an ro showing you had a complaint about death wobble prior to your warranty expiring? You might be able to get a track bar goodwilled by the dsm if you can prove you had that issue before the warranty was up.
Gun control is like trying to reduce drunk driving by making it tougher for sober people to own cars.
dazed01 is offline
post #9 of 35 Old 07-01-2012, 11:26 AM
bentstroke_02's Avatar
man dont truck those people they are just trying to make extra money off of you. If you know what your doing crawl under it and check it all yourself. Or if you have a friend that knows his stuff take it to him
Jeremiah
Horsepower is like sex, once you get it you can't get enough of it
2008 6.4 with 200k and counting
5" FLO-PRO exhaust W/6" tip
AFE stage 2 CAI
Spartan tuner
PTP EGR Delete
coolant filter
CCV Mod
leveling kit
4in rear Blocks
20's W/35's
bentstroke_02 is offline
post #10 of 35 Old 07-01-2012, 11:37 AM Thread Starter
Quoted: 19 Post(s)
Yes, there is a line on my last work order to investigate the cause of my worsening death wobble. My service writer is going to talk to the service manager. Apparently, there is some sort of program in place where Ford, the dealership, and the customer split the cost of the repair when there's issues that arise just after warranty expiration but have been documented prior to warranty expiration. Believe that the customer pays 15 or 20% of the repair cost and the rest is covered by Ford and the dealership. Only downside is that it will only cover OEM parts and I eventually want to lift my truck so I kind of want to go with the biggest, burliest components I can so I don't have to upgrade/replace them later.
Putco Window Visors
Line-X
Bak Flip F1
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
4" Solstice Prime
Truck Bed Lights
