ac not cold - Ford Powerstroke Diesel Forum
Old 06-28-2012, 11:58 PM
ac not cold
kinda cool but not cold. barely cooling the cab. been 100*+ in houston lately but i shouldnt be sweating my butt off in the cab. windows tinted. both sides equal temps so i dont think its the blend doors. where/how should i start the troubleshoot?
Old 06-29-2012, 03:52 AM
Turn the temp down and the fan up JK Hopefully it's just a switch or fuse....pray for something simple! I just replaced the entire AC system on my 07 Freestyle....not fun! Best of luck and keep us updated.
Old 06-29-2012, 09:27 AM
Check the freon charge. The low side port is a PIA to get to. Its behind the air box, againt the firewall, under the computer wiring connections
Old 06-29-2012, 10:05 AM
I would take a look at A/c high and low side pressures and if they are low I'd recharge it and add dye and use a uv light and goggles to find what is leaking.
Old 06-29-2012, 10:29 AM
I have the same issue, it blows fine just not very cold. I put a thermometer in the vent and it read anywhere from 64 to 70, and that was set on the coldest setting. I haven't checked the freon yet, that's probably where I will start.
Old 06-29-2012, 01:23 PM
alrite ill that first.
Old 06-29-2012, 02:42 PM
I had a similar issue in my car. Turned out to be the condesor. Had to replace it.
Old 07-01-2012, 08:23 AM
I notice during really hot days here in NorCal, the A/C gets cold but it takes a little bit...like 5-10 minutes or so. It seems to be ok after the initial cool down.
