Crushed bushing up front.
Was under front of truck recently and noticed the cab bushing up front near tire on passenger side is crushed. Its not the bushing between the frame and cab but the one most underneath that sits against the big flat washer and frame. Can i order just this bushing somewhere and if so, can i just undo the nut and washer, slide off the old one and reinstall a new one? Thanks
Is it the dust seal that is crushed?
It is the lower isolator bushing. It is donut shaped.
Is it between the washer and the frame mount? I assume its diffrent from the other mounts? If it is what I think it is, then yes you can remove the nut(usually its a bolt going up thru but I haven't looked to see for sure) and replace the bushing, although you will have to probably buy the whole mount bushing set for that corner. You'll have to check with your dealer. Pics would help.
