Driveline Chirping/squeak - Ford Powerstroke Diesel Forum
post #1 of 13 Old 06-26-2012, 04:34 PM Thread Starter
gmw33's Avatar
Het guys, Im having kind of an annoying issue with what seems to be something in the drivetrain, wheels or brakes. Truck is lifted 6 inches and what happens is that after i have moved the truck about a mile in the morning i get a chirping/ squeaking sound from under the truck that corresponds with how fast the truck is moving, Pushing the brakes does not change the sound so I kind of want to rule them out, I've had two local mechanics look at it because I thought it would be a rear u joint, they said the u joints look fine.
Anyone have any ideas what could be causing this? almost seems like it happens once a bearing gets warmed up, carrier bearing maybe? front drive shaft?
any help is appreciated.
gmw33 is offline
post #2 of 13 Old 06-26-2012, 07:59 PM
Maybe the carrier bearing..... Does it need a spacer after lifting?
Refugio is offline
post #3 of 13 Old 06-26-2012, 08:00 PM Thread Starter
gmw33's Avatar
The Fabtech kits dont come with it, Its been lifted for awhile but the bearing is the only other thing i can really think of that would squeak like that, is there any way to check it?
gmw33 is offline
post #4 of 13 Old 06-26-2012, 08:05 PM
Not sure how to correctly check it.
Perhaps you could lube it up with some spray oil and then see if the chirping goes away and if it does ....... Then change the carrier bearing as the oil will not last very long.
Just thinking out loud.!!!
Refugio is offline
post #5 of 13 Old 06-26-2012, 08:11 PM Thread Starter
gmw33's Avatar
I did try that recently, however it is hard to judge since it seems it takes the chirping awhile to start in the first place
gmw33 is offline
post #6 of 13 Old 06-27-2012, 08:43 AM
wilsonw2's Avatar
Quoted: 18 Post(s)
Tensioner pulley? i just recently had one replaced due to a squeak under the hood. Check all pulleys to make sure there isn't any movement.
*NEW:
2016 F250 CCSB KR FX4
NL Fab:
---Stage 1 Intake
---EGR shmock off plates
---Flo Pro Exhaust (5" to 6" tip)
---SCT with GH tunes
---Waiting for first Fuel Filter change to install:
---------CCV Mod
---------CTS2 monitor with EGT Probe
Just passed 1,111.1 miles and LOVING IT!
**SOLD:
2010 F250 CC FX4
H&S
AFE Intake
and some other goodies...
wilsonw2 is offline
post #7 of 13 Old 06-27-2012, 10:06 AM Thread Starter
gmw33's Avatar
It seems like its coming from under the truck mostly
gmw33 is offline
post #8 of 13 Old 06-27-2012, 10:11 AM
kingranch250's Avatar
Of they just looked at the u joints they can look good n still be bad pull the shaft off rear end and move the joint see if its hard to move or has a tough spot in it. Have u ruled out wheel bearing?
auto merter gauges,03turbo,volant intake,SCTcustom tunes,Harley headlights,recon smoked tail/3rd break,5 inch exhaust 8inch stack,billet grille,jessejames lawsless 20's 33"mud grapplers, jesse james door handles,arp head studs,oynx gaskets,upgraded banjo bolts,river city egr delete kit,air dog 150, 08 tailgate,all lights led,mp8
kingranch250 is offline
post #9 of 13 Old 06-27-2012, 10:13 AM Thread Starter
gmw33's Avatar
The first mechanic pulled everything off and said it looked good, I have not ruled out wheel bearing. Is there a way I could check that? I hate to go replacing a bunch of things if it's not needed.
gmw33 is offline
post #10 of 13 Old 06-29-2012, 03:22 PM
I hear the same thing on my truck but only when it wants to. Stock height never lifted. 113k now
Sent from my LG-P509 using AutoGuide.Com Free App
08 CC SB
Fun Stuff
Mini Max / S&B Intake / 4" MBRP DP / 5" MPRP DP Back / 5" x 6" x 18" MPRP BLACK Tip
Normal Stuff
10" shallow RF sub w/ custom box & amp rack / Xtant 600W amp / Tinted front windows to match factory rears / Recon bed lights
08SuperDiesel is offline
