sigh.....broke my water trap valve lever - Ford Powerstroke Diesel Forum
post #1 of 13 Old 06-24-2012, 09:33 AM Thread Starter
Doing my first maintenance for my 6.4 and I dont think the old people before me did much maintenance on this thing. The oil was think and BLACK. A day later its still on the side of the bucket. Well I went ti change the fuel filter and first went to drain the water trap next to the frame rail filter and couldn't budge it. Hap to start it with a screw driver inorder to get my fingers behind it. Once I got it started I used my fingers and ended up breaking it in the open position. I managed to unscrew the 3 little bolts enough to not make the lever soo tight and could close the valve nub with a screw driver, erg!!!
blk450er is offline
post #2 of 13 Old 06-24-2012, 09:41 AM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
I am not a fan of the design at all
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, PHP Hydra, 4" DP, Napa Intake, coolant filter, 140cc AD Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #3 of 13 Old 06-24-2012, 01:11 PM Thread Starter
is there a fuel shut off somewhere so when I'm changing the valve out it wont keep leaking fuel on me? Also, can I just replace the valve (with the plastic lever) and gasket behind that little plate with the 3 screws?
blk450er is offline
post #4 of 13 Old 06-24-2012, 01:13 PM
Quoted: 6 Post(s)
I am not sure on either question but it should not be to hard to change out the valve.
post #5 of 13 Old 06-24-2012, 01:42 PM Thread Starter
I dont think it will be. Already had the three bolts loosened up in order to close the valve with a screw driver, but more fuel started coming out. I just didn't know how much would come out by taking the little plate and valve out? Almost 1/2 gal came out im guessing.
blk450er is offline
post #6 of 13 Old 06-24-2012, 03:13 PM
Quoted: 6 Post(s)
Ya it will drain the whole line
post #7 of 13 Old 06-24-2012, 05:17 PM Thread Starter
cool, shouldn't be too bad changing it then
blk450er is offline
post #8 of 13 Old 06-25-2012, 08:28 AM
macgyvr's Avatar
I changed the one on my F450 when I had it.
It was easy and you can get the lever from the dealership and its not that expensive.
mac 'only as much fuel comes out as when you change the fuel filter' gyvr
2008 F350 Lariat 6.4 dieselcrew cab dually 4x4 4.10s 135k
DPF/Cat/Muffler delete, AFE air box, H&S minimax, B&W goose, Tinted Windows, air bags, procomp traction bars
"Fight socialism buy a FORD"
macgyvr is offline
post #9 of 13 Old 06-25-2012, 08:48 AM
Quoted: 2 Post(s)
I did the exact same thing yesterday. I am glad to hear that it is easy to fix and inexpensive.
713Diesel is offline
post #10 of 13 Old 06-25-2012, 08:52 AM Thread Starter
Just ordered it from the dealership today and should be here tomorrow. Looks like it comes with the plastic valve, some rubber o rings and maybe some new bolts. Hopefully it turns better than the origional one.
blk450er is offline
