2 engines toasted in 3 weeks due to bad EGR coolers
When will Ford take responsibility for their piss poor design? I mean, I use my truck to make a living. I thought I had blown my first engine due to some tech's wrongdoing. However, when I had the engine replaced they showed me it was a faulty EGR cooler. I already had my check from the maintenance shop to keep my mouth shut. i wasnt losing any money....
So I got a Ford dealership to install a new engine with a 2 year unlimited mile warranty. Seemed like a pretty good deal. i wasnt out any money. Well new engine in (after waiting 2 weeks) and i start taking my truck back to the house. 350 miles into the trip, im overheating...AGAIN! needed a new radiator (or so they said). had it repaired and then picked up my gooseneck. made it from alabama to the middle of New York city with a very light load, stop at a rest area, and BOOM. a plethora of white smoke and rough idle upon cranking. after letting it idle for about 30 seconds, it would smooth out and no smoke. Well, I had to get it to a shop to have it checked out. so i pull out of the rest area and slowly, carefully head to the exit. in a surge....and this is not BS, my temp shot to high then I hear a pop and a bunch of rattling. needless to say, I was cursing more than a sailor on the day he was getting redeployed. White smoke. No coolant. And no warning. the shop checked it out. bad EGR cooler. Less than 1500 miles from having a new engine, new EGR, new regen filters....the works. another blown engine. thousands of dollars lost. and my heart broken. i should have bought a dodge. and regretfully, i seriously mean it. |
Wow, really sorry to hear that. Is your truck stock and how many miles?
2008 f-450. returned to stock condition at last engine replacement. apparently, it had a programmer on it when i bought it which most likely contributed to the EGR failure.
motor blew at 121648 and 123148....yes, exactly 1500 miles on the new engine. |
That definitely sucks but why is this Ford's fault?
That really sucks man but I don't think the programmer caused it. It would have just been faulty coolers. Anyways hopefully they get it fixed up for you soon. Are you in an area where you can remove the egr & dpf system?
Sent from my DROID RAZR using AutoGuide.Com Free App
It depends on the tuner. Some turn the EGR system completely off and others will still cycle the EGR. This can cause the EGR valve to stick. When the valve opens, carbon starts building up in the intake manifold. What I'm getting at is if the coolers weren't deleted/removed when the original owner had the truck and tuner, the valve may have been stuck when the new owner, the OP, bought the truck without the tuner, causing the coolers to fail. As far as the second engine, not sure why it would fail.
tearing up a brand new reman 6.4 shouldnt happen...especially not 1500 miles into its install. And Ford knows their EGR design is flawed...yet they keep on installing them and as of yet, have failed to issue a true fix to their flawed design. Isnt it about a grand to replace the EGR coolers? and how can you really know its about to fail? Why is it my responsibility to buy aftermarket junk when ford should stand behind their product off the showroom floor? I mean, 100k mile warranty on a vehicle that can easily run 50,000 dollars new...conceivably, id have to make at least $5 per mile in order to break even. No hotshot in the world can do it.
Ford "Like a rock".....yeah....right. Like a ****. |
