08 6.4 temps???? - Ford Powerstroke Diesel Forum
Old 06-14-2012, 11:44 AM
08 6.4 temps????
Just bought an 08 6.4 job 1 truck with 80k on the clock. My question is what are the temp deltas suposed to be on these trucks and will my scan gaugeii read them? Also any other problems I should be looking for or parts to add? I've ordered a Dpf delete exhaust and coolant filter. I have a sct x3 can I get custom tunes to work with the dpf delete? Thanks
Old 06-14-2012, 12:43 PM
Dont Mess With Texas!
Congrats on the new rig
Originally Posted by tyoung911 View Post
Just bought an 08 6.4 job 1 truck with 80k on the clock. My question is what are the temp deltas suposed to be on these trucks and will my scan gaugeii read them? Deltas should be around 4* to 15* max, anything more than that oil cooler might be clogged, yes i do beleive the scan guage will read themAlso any other problems I should be looking for or parts to add?check the radiator for coolant leaks, that is the #1 problem with these trucks I've ordered a Dpf delete exhaust and coolant filter. I have a sct x3 can I get custom tunes to work with the dpf delete?Yes, look into KEM tunes they are great be sure you have DPF delete tunes on prior to removing the DPF or you could run into some issues Thanks
Old 06-14-2012, 12:57 PM
My ect/eot delta is 4-6 degrees even as high as 8 just for a couple seconds though till the ect catchesd up, tranny anywhere from 155-170.
