Alignment specs - Ford Powerstroke Diesel Forum
Old 06-12-2012, 08:58 AM
Alignment specs
Any one have the Alignment spects for a 08 450 4x4?
With my 4 link the shop around here don't want to touch it and will not give up the spec.
Toe, Camber, Caster
I have added -3 degrees caster to get the truck to stay between the lines,
Took my digital level and found the front wheels are at a -.5 deg camber. I have the adjustable shims to fix just need the factory specs to work with as a starting point.
I figure Toe to be 1/8 to 1/4 inch toe in
Cheers
Old 06-12-2012, 05:37 PM
Wouldnt mind knowing myself.
Dont know the exact but I think Ive heard 3-5 degrees + caster.
Was your toe off before you added four link? I need to get mine checked as well since lifting and adding 4 link..
Old 06-12-2012, 05:38 PM
Double post..
Old 06-12-2012, 08:46 PM
Feedback Score: 7 reviews
I got mine done and it looks like they took everything to zero. I will have to double check.
Old 06-13-2012, 03:51 AM
The Initial issue was the truck tracked great in a corner but in a straight line it was all over the place.
Steering box... Replaced
Drag link.... Replaced
Ball Joints ... replaced
Addred a Four link and Air bags and when I did so I cranked in 3 degrees of negitive Caster. WOW the truck runs fairly straight still wanders on a straight and flat road.
I have an upgraded Track bar to install this week ( Adjustable) with a upgraded joint at the frame (No rubber) thsi should help with some of the wander.
Shade tree measurements for Camber using a digital level 1 decimal place to the right, Zeroed the level on the axle tube. Next Placed on the left and then right wheels ( measured Vertical deflection) the wheels showed a negitive .7 and .5 measurement. While this doesn't sound like much, I remember from my racing days a half degree of camber did make a big difference. +3 to +5 sounds like a lot, any Ford Mechs on the forum can you confirm?
Toe, Toe did not change when I installed the four link did nto mess withthe tie rod at all during the installation. Plus my installation only gave me about a inch in lilft. If the Caster is set correctly you should not get any toe change.
Old 06-13-2012, 05:51 AM
I can see the camber specs being around 0 to -0.5, that makes sense, but the castor I recall should be around +3 to +5, which should track straight(er), mostly everything nowadays has positive caster. Not sure if one side would be slightly less to account for road crown or not.
Old 06-13-2012, 06:12 AM
My Bad,
I ment Positive caster angles not negitive.
Cheers
Old 06-13-2012, 09:17 AM
Feedback Score: 5 reviews
Set castor to 4.5-5*
Toe 1/16-1/8"
camber 0 if possible.
Old 06-13-2012, 09:25 AM
Thanks Cary,
I knew you were lurking around here someplace.
Cheers
Old 06-13-2012, 11:09 AM
I will post what tire discounted set mine to today or tomorrow. The truck tracks pretty good except on the highway it pulls just slightly to the left. So slight that I didn't think it was a big deal but I guess it is?
